Old 07-05-2008, 11:39 PM   #1
Car: 07 sti
Fav Mod: whats a mod?
Default water in catch can?
so far i havent had any oil in my catch can, just water! anyone else catch just water? i would guess appx. 2 oz in about 1,200 miles. im glad i didnt plumb it to drain into the oil pan! i didnt think there would be that much condensation in the crankcase.
Old 07-06-2008, 09:34 AM   #2
If in doubt, flat out
Trader Rating: (23)
Default Re: water in catch can?
I noticed water would condense in the cans (one can in particular, I can't recall which system it was connected to) after doing a lot of city driving. I've tried at least four different CC setups with limited success. what kind of can(s) are you using? Lack of baffling seems to be the problem with most CCs not condensing oil vapor.
Water is a byproduct of combustion, it's normal.
Old 07-06-2008, 10:04 AM   #3
Car: 07 sti
i have a provent. im pretty sure the little bit of oil i go thru is being burned at cold start (loose forged pistons), so im not worried about almost none being in the catch can.
Old 07-06-2008, 10:07 AM   #4
Trader Rating: (23)
Is your intake system clean? That's my problem. The oil vapor still condenses in the IC and Manifold just as much as it did w/o cans.
Old 07-06-2008, 10:35 AM   #5
Car: 07 sti
my breather system vents thru the catch can into the atmosphere so nothing can dirty up my intake.
Old 07-06-2008, 01:22 PM   #6
Car: 04 Sti Wrb on Silver
My cc is plumbed rather same way but the line coming out of the pcv sistem is plumbed to the catch can and then back to the intake. The breather lines from the heads are atmospheric. So far I haven't gotten any problem and everything is clean.
Old 07-06-2008, 02:13 PM   #7
Car: 07 sti
my pcv isnt even hooked up anymore! nothing can possibly get in my intake unless the turbo blows and spits oil out of the compressor.
Old 07-06-2008, 02:16 PM   #8
Yey for pollution
Old 07-06-2008, 02:22 PM   #9
Car: 07 sti
Yey for pollution
my catch can is carb approved.
