Old 07-05-2008, 04:27 PM   #1
Car: 07 sti
Fav Mod: whats a mod?
Default stock pistons rule!
finally tore down my stock block to part it out.
Old 07-05-2008, 04:30 PM   #2
Default Re: stock pistons rule!
So thats what happened when you took the piston out? Or the motor blew and thats the aftermath?
Old 07-05-2008, 04:34 PM   #3
Car: 07 sti
that happened because of the early timing issues on modded 07's. i think they figured it out the week after i busted the ringlands.
Old 07-05-2008, 09:01 PM   #4
Closer to Madness.....
Car: 07 WRX STI (OBP)
Fav Mod: Power Enterprise 1820F
What kind of symptoms did you have when the ringlands went boom???????
Black_Sun is offline   Reply With Quote
Old 07-05-2008, 09:05 PM   #5
"that happened because of the early timing issues on modded 07's"
What exactly does that mean? What mods did you have? And in what order?
Old 07-05-2008, 10:04 PM   #6
Car: 07 sti
i was heavily modded with big injectors and an upgraded turbo. 390 whp. basically, the big problem was the lack of tuning info. there are 4 ignition maps and 2 have to be disabled or else they can over advance the timing and cause busted ringlands. any good tuner can tune the 07's now to be as reliable as any other year. mine was tuned a year ago, before the info was avaliable to properly tune them.
Old 07-06-2008, 10:03 PM   #7
Car: '07 STi Limited #482
It is somewhat known now what the DA 'A' and 'B' maps do (info can be found on the romraider site). Knowing it, I still prefer to zero them out.
Old 07-06-2008, 10:05 PM   #8
Car: Turd brown 07 STI
Fav Mod: 170mph!
2nd that!!^^
Grey Ghost is offline   Reply With Quote
Old 07-06-2008, 11:55 PM   #9
Car: 07 sti
oil smoke in the exhaust under heavy boost, low vacuum, not hitting target boost, hard starting, etc.
Old 07-07-2008, 07:33 PM   #10
Fav Mod: 170mph!
how can you tell if you have low vacuum?... and the oil somke in the exhaust?( could you see it coming out when you were flooring it ...or did you smelll it? ( if you smelt it how did it smell? ) also wat color was the smoke..blue , or black
Old 07-09-2008, 01:35 PM   #11
Car: 07 sti
i have a vacuum/boost gauge so i can see vacuum. i saw the oil smoke between shifts when racing it around. the smoke was dark, my windows are tinted so it was hard to tell what color, but it should dark with a bluish tint.
Old 07-09-2008, 02:35 PM   #12
Fav Mod: Peter Solberg Autographed my STI
Anyone concerned about a busted ringland can turn their car on and take off their oil filler cap. Under most circumstances, oil will be splashing out of the oil filler. There will also be a noticable amount of exhaust coming out of the oil filler that will plume with the cycle of the motor.
Another way to tell is to drop the headers and look for oil in the headers.
And yet another way is to just do a compression leak down test.
Sorry for your loss there n2oiroc but it looks like you have it under control. I have a smoked ringland in my 04 STi but unfortunately I deployed to Iraq before I could drop in a new block. at least I'll have something to do when I get home
EuroScuby is offline   Reply With Quote
Old 07-10-2008, 09:35 AM   #13
Fav Mod: 170mph!
Thanks for the info!^
