Old 06-21-2008, 01:38 PM   #1
Car: '07wrbSTi
Fav Mod: Invidia G200
Default protuned stage 2 07sti vs. ots stage 2 04sti - HELP!
i am looking for an explanation here, very confused.........
07sti with a protune, running 3" invidia catless bellmouth turboback, fuel pump, aps cai, mbc is making 290whp & 300wtq.
the 04sti with an ots cobb stage 2 map, catted dp, full turboback, an af intake (forget what) is making 309whp & 320wtq.
curious to know what the diff. could be? same dyno, diff. days. within 2 weeks of one another. temp. was about the same. can't recall humidity though.
any ideas would be appreciated.
thanks all!
kiwee is offline   Reply With Quote
Old 06-21-2008, 01:41 PM   #2
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Default Re: protuned stage 2 07sti vs. ots stage 2 04sti - HELP!
weather?....dyno's?
Old 06-21-2008, 01:41 PM   #3
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
thanks all!
Some cars react well to the OTS maps. Other than that, some cars are just simply stronger than others.
Was this done on the same dyno, the same day? Maybe you have a "safer" tune? My point is, there are a lot of variables.
Old 06-21-2008, 01:45 PM   #4
Car: '07wrbSTi
sorry guys, same dyno, diff. days. within 2 weeks of one another. temp. was about the same. can't recall humidity though.
Old 06-23-2008, 03:35 AM   #5
Car: '07wrbSTi
bump!!!
Old 06-23-2008, 08:16 AM   #6
Car: 05 Subaru STI
how about showing both plots with afr's and boost?
Illusive is offline   Reply With Quote
Old 06-23-2008, 08:29 AM   #7
Car: traded 04 w/128k mi.
This is more common than people think. With my 04, the OTS map put down much better numbers over my protune. I do hoever think that the tune with the OTS wasn't as nice. With a protune, you're much safer and better over all. Who gives a crap about dyno numbers, it's all about real life power. I'm sure with the protune your car is happier.
MaSTi04 is offline   Reply With Quote
Old 06-23-2008, 08:29 AM   #8
Car: aspen 2005 wingless
sounds like someone is running 2 psi more than the other. Post up the plots!
Old 06-23-2008, 03:33 PM   #9
Car: 07 Subaru STi
Fav Mod: Coilovers/Tune
Send a message via AIM to IGoFast1589
What about correction?
IGoFast1589 is offline   Reply With Quote
Old 06-23-2008, 05:39 PM   #10
Car: 07 OBP/Gold STi
Fav Mod: DomTune & MD Whisper
more aggressive tune on the 04 probably... if you're really worried about it (I wouldn't be) you can call your tuner.
Loubaru is offline   Reply With Quote
Old 06-23-2008, 05:44 PM   #11
Car: 04 WRB sti
probably that 04 is holding more boost at redline than yours.
stageII-291whp@19psi
lapinga is offline   Reply With Quote
Old 06-23-2008, 05:45 PM   #12
Car: 07 STI OBP
that 04 is prob at the limit
Old 06-23-2008, 05:59 PM   #13
any chance u think that might has something to do with the DCCD Front/Rear Split. U know the 04/05 is runnig 65/35, and the 06+ is running 59/41?
Old 06-24-2008, 05:47 AM   #14
OpenSourcerer
Fav Mod: ECU
I bet its the MBC. Car for car, the 07 should put down more power. The Cobb OTS map your friend was running had learned timing and fuel trims as well. Your car is tuned to your car at one particular time and is capped at that HP and TQ level. You also have an MBC, so your tuner probably tuned even more conservatively than if you had not (people like to turn that knob for some reason).
