Old 06-19-2008, 08:37 PM   #1
Car: 2004 STi Blue
Default Best Mods before a stage 2 Pro Tune.
Sup guys, ive owned my 04 STi since it has 0.3 miles on it. And Recently i have been getting bored of the power. I have installed over time a Cat back exhaust, and Cold air intake and Blow Off Valve for asthetic purposes. Well i just recieved my megan downpipe from a online user. So i have recently decided to go with a Pro tune from a local tuner in the SoCal area that i hear is really good. So with the downpipe i have what i need to go stage 2. But i want to throw something else in the mix since im goin to spend the money on a pro tune.
Here is what i have came up with.
It can only be one but i dont know witch one witll give me better gains.
1.Exhaust Manifold Crossover Pipe
2.Uppipe
3.Walbro Fuel Pump
4. Injectors
That is alll i have came up with. So with the addition of a new DP what else should i get that will gain my car the most power? Preferebly top end! All help is greatly appreciated! Also since in installing the downpipe is it worth it to get the waste gate port and polished?
04_Sti_Blue is offline   Reply With Quote
Old 06-19-2008, 08:50 PM   #2
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Default Re: Best Mods before a stage 2 Pro Tune.
Who's tuning the car?
First things first, get rid of the BOV
A Walbro wouldn't hurt. That & what you already have is all you really need.
Old 06-20-2008, 04:37 AM   #3
Car: 05 CGM STI
Fav Mod: Being Unbeatable
the walbro and fuel injectors wouldnt hurt at all, so ur tuner cant run out of fuel to play around with when tuning
zim2322 is offline   Reply With Quote
Old 06-20-2008, 10:17 PM   #4
Fav Mod: exhaust
Send a message via AIM to krich
Headers and up pipe would be nice. Dont really need to up grade the fuel components yet until turbo upgrade.
krich is offline   Reply With Quote
Old 06-20-2008, 11:58 PM   #5
Car: 05 STI, 03 Cobra
In my opinion the fuel pump is necessary for a protune, it is just insurance. You shouldnt max out your stock injectors with a stg 2 setup, so those will be fine.
None of your other mods will net you that much power and are probably just a waste of money if you arent going to add a different turbo.
Have you thought about getting your stock turbo ported and coated, that will help with spool and it will keep under good temperatures down.
'05CrystalGray is offline   Reply With Quote
Old 06-21-2008, 12:02 AM   #6
Trader Rating: (15)
Get rid of the BOV, electronic boost controll selinoid(bcs), and fuel pump. All you really need. you'll be happy with the numbers!
Old 06-21-2008, 12:28 AM   #7
Fav Mod: exhaust
you're not even close to maxing the injectors on stage 2. Fuel pump is not necessary unless you have a regulator
Old 06-21-2008, 04:47 AM   #8
BWG
Car: Blue 04 STI
BS, I maxed the stock injectors with a stage 2 protune.
BWG is offline   Reply With Quote
Old 06-21-2008, 05:57 AM   #9
Car: 2008 STI
Send a message via AIM to FlyingPerformance
Get an aftermarket BCS(I make a BCS kit), walbro, and if you want to injectors. I have a tuned stage 2 car with a Walbro, APS CAI, BCS, and a TurboXS TMIC and came close to maxing my stock injectors. The deal with running out of fuel or not when tuning a stage 2 is all in how the tuner gets the power out of the car. I am not a tuner, nor do I claim to be, but there is more than 1 way to skin a cat when tuning these cars: more fuel, more timing, more boost, etc.... You could run a meth injection setup and keep the stock injectors. You would pick up more power and still be safe with your stock injectors.
FlyingPerformance is offline   Reply With Quote
Old 06-21-2008, 02:58 PM   #10
LSE
Fav Mod: Defi Gauges
I got:
header + uppipe.
injectors.
CAI.
I already had the pump.
Old 06-22-2008, 01:43 AM   #11
Fav Mod: EQ road tune
Decide your budget, then talk to your tuner and ask what they prefer. You dont want to buy a short ram intake and then find out your tuner prefers a cold air intake. Some tuners can be picky.
suby OCD is offline   Reply With Quote
