Old 06-16-2008, 06:50 PM   #1
Car: The Vroom-mobile
Fav Mod: JDM Gears
Default Car won't start, please help
I took off my intercooler to redo some breather lines that didnt sit right, i put everything back together and now the car wont start. THe throttle body hums for some reason and everything seems fine until i go to start the car, everything just blinks really fast and i hear a click sound. ANy ideas?!
Old 06-16-2008, 06:52 PM   #2
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
Default Re: Car won't start, please help
You check your IC hoses, and check your fuses.
Old 06-16-2008, 06:54 PM   #3
Fav Mod: JDM Gears
fuses seem fine, the IC hoses seem fine...I also have all the breather hoses on and everything. Did i miss something?
Old 06-16-2008, 07:02 PM   #4
Fav Mod: JDM Gears
double check, the humming is deffinately coming from the throttle body
Old 06-16-2008, 07:04 PM   #5
HowTo Contributor
Fav Mod: Stg 2 - STRI gauges
disconnect battery? hope it wont mess anything up but its an idea
Old 06-16-2008, 07:06 PM   #6
Fav Mod: JDM Gears
tried that, its almost as if theres a short when i try to start the car.
Old 06-16-2008, 07:07 PM   #7
HowTo Contributor
No idea sorry
Old 06-16-2008, 07:14 PM   #8
Car: '05 WRB STi
Fav Mod: JDM magnectic drain plug yo
Just a thought but mabey you should check the little actuator that opens and closes the butterfly valve at the enterance of the throttlebody, on the left hand side facing the engine
Evan is offline   Reply With Quote
Old 06-16-2008, 07:14 PM   #9
Fav Mod: Stereo
no starter or anything? Just clicks? It's not the clicking as if you have the test wires hooked together is it? (Like when you marry an AP)
Otter is offline   Reply With Quote
Old 06-16-2008, 07:20 PM   #10
Fav Mod: JDM Gears
do you have a picture? i have no clue what im looking at
Old 06-16-2008, 07:21 PM   #11
Fav Mod: JDM Gears
everything blinks really fast, i know its a short because it resets my radio's stations to default
Old 06-16-2008, 07:26 PM   #12
Car: '05 WRB STi
Sorry I don't. It's extremly easy to see though. Big black square thing on the left hand side with wires coming out of it right at the enterance to the throttlebody. I'm just brainstorming though, I might be way off target here. ^^;
Old 06-16-2008, 07:30 PM   #13
Car: Black 07 WRX STI
Fav Mod: AP
Dam I hope you figure it out.
STUKA is offline   Reply With Quote
Old 06-16-2008, 07:32 PM   #14
Car: 06 Subaru WRX STi
check the connection at the top of the alternator. If its loose it will cause wierd problems.
Old 06-16-2008, 07:34 PM   #15
Fav Mod: JDM Gears
i went to check actuator and it is indeed the item that is doing the humming, but why?
