Old 06-16-2008, 07:35 PM   #16
Car: The Vroom-mobile
Fav Mod: JDM Gears
Default Re: Car won't start, please help
Originally Posted by halfelite View Post
check the connection at the top of the alternator. If its loose it will cause wierd problems.
going to go check that now
KiTsuNe is online now   Reply With Quote
Old 06-16-2008, 07:40 PM   #17
Car: 06 Subaru WRX STi
Originally Posted by KiTsuNe View Post
i went to check actuator and it is indeed the item that is doing the humming, but why?
Its normal to humm. If you turn your car to acc it will hum. At least mine does.
Old 06-16-2008, 07:44 PM   #18
Car: '05 WRB STi
Fav Mod: Open Downpipe
Now it gets tricky. I'm not sure if the actuator is the problem or a symptom of something else that's wrong. I'd check the wires coming out of it to make sure none got pinched when you put the IC back on.
Evan is offline   Reply With Quote
Old 06-16-2008, 07:44 PM   #19
Fav Mod: JDM Gears
the alternator seems fine, is there something that could cause a short somewhere?]
it seems to short out when i try to start the car
Old 06-16-2008, 07:51 PM   #20
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
that will happen when you blow a big ass fuse, like a 100. Check those, same thing happened to me...
Old 06-16-2008, 07:53 PM   #21
Do you have a test light to find a short?
Old 06-16-2008, 09:00 PM   #22
Fav Mod: JDM Gears
Found the problems, was more then one. Thanks to morepsithebetter we figured it was my map sensor, then the second problem was i need a new battery.
I reconnected the map sensor and jumped the car and now it works.
Old 06-16-2008, 09:07 PM   #23
HowTo Contributor
Fav Mod: Cobb Stg 2 - Wrapped DP
Congrats
Old 06-16-2008, 09:09 PM   #24
Fav Mod: JDM Gears
thanks, now i need to buy a new battery...probably a light weight one
Old 06-16-2008, 09:10 PM   #25
HowTo Contributor
braille?...
Old 06-16-2008, 10:10 PM   #26
Fav Mod: JDM Gears
Originally Posted by Bishop View Post
braille?...
ive heard bad things about braille though
Old 06-17-2008, 05:31 AM   #27
Fav Mod: Stereo
LOL yeah, as I recall they just repackage a motorcycle battery
Otter is offline   Reply With Quote
Old 06-17-2008, 08:57 AM   #28
Fav Mod: GST Protune, less boost more power
Send a message via AIM to MorePSiTehBett4
suck's about the battery my friend...take it up to kragens and let's do a battery test, they can figure out if it's STill good or not...hopefully it's not the dreaded ~50,000 mile alternator failure that some of us get...
yah under the red rubber cap(mine came loose for some reason) where the alternator has a bolt that it is just held up by a nut sometimes it just get's loose and needs a re-tighten(sounded like broken engrish )
MorePSiTehBett4 is offline   Reply With Quote
Old 06-17-2008, 10:59 AM   #29
Car: 04 Sti Wrb on Silver
A Subaru mechanic told me that the humming sound that comes from the throttle actuator motor is normal, its like a calibration phase at startup.
Whats this about 50,000 miles alternator change??? i had to replace my power steering pump due to hard auto x sessions and some off roading weekends.
Old 06-17-2008, 12:51 PM   #30
yah we lose are alternators before 100,000 miles; i've seen it on the forums quite a bit
