Old 06-13-2008, 09:24 AM   #1
Car: 07 UGM STI
Fav Mod: Police Scanner
Default Big Injectors... need advice
I'm in the process of planning my turbo upgrade and will need to get bigger injectors since I run E85. I'm currently running 830cc modified stockers (which will be for sale soon). The car will need 1000 to 1200cc (not sure yet) to run E85. Luckily I can do top feeds since it is an 07.
I've looked at RC Engineering, Ultimate Racing, and Deatschwerks. Here are the prices:
Ultimate Racing:
1000cc Flow-Matched Fuel Injector Kit $525
Deatschwerks:
1100cc $599
RC Engineering:
1000cc $400
Anyone have experience with these brands or can you suggest others? I'm not looking to cut corners.
Thanks!
csschupp is offline   Reply With Quote
Old 06-13-2008, 09:31 AM   #2
OpenSourcerer
Fav Mod: ECU
Default Re: Big Injectors... need advice
DW all the way. Man, those injectors are perfect. They really do a good job on them. Plus, you get a refund when you send your old ones in.
I have tuned several and DW by far has hit fuel targets dead on every time. All of the others are a bit off at times. Their customer service is top notch as well. Mike and David are great guys.
I even told one guy to get rid of his decapped stockers and get DW because the fueling was bouncing around. With the DW injectors, the WBO2 reported fuel targets dead on after scaling them. No wobbling, just a dead on fuel curve that lined up perfectly with the OL fueling map (after getting the scaler right which is almost always near the advertised CC/MIN).
I have gotten so good at tuning DW injectors, that I can just guess at latency and scaling and it is almost dead on (as long as the MAF sensor is ok).
I wish I had the pumps around to go straight E85, instead I am using Meth which is an additive to the gasoline and will not get the same power you will get once you have the fueling headroom (if I still had the stock turbo. ). I would have to upgrade my DW 750's though to run straight E85. But it would work so much better than Meth injection and more reliable.
Old 06-13-2008, 09:36 AM   #3
Car: 07 UGM STI
I have tuned several and DW by has hit fuel targets dead on every time. All of the others are a bit off at times. Their customer service is top notch as well. Mike and David are great guys.
This seems to be the general consensus. I guess you really get what you pay for with injectors then?
Old 06-13-2008, 09:45 AM   #4
OpenSourcerer
Fav Mod: ECU
Yeah you do. Don't forget you get a core refund too, so the increased cost is offset.
Old 06-13-2008, 10:13 AM   #5
Muller Chevrolet
Fav Mod: a new 08 STi
yea DW is great, i plan to upgrade to the 1100's.
Old 06-14-2008, 08:02 AM   #6
Car: 2008 STI
Send a message via AIM to FlyingPerformance
Go with the DW.
FlyingPerformance is offline   Reply With Quote
