Old 06-16-2008, 08:18 PM   #46
Car: steel grey 06 sti
Fav Mod: sz49 8cm
Send a message via AIM to beecha91 Send a message via Yahoo to beecha91
Default Re: Latest Drive Magazine on how to care for your Turbo motor
Originally Posted by gabedude View Post
When you try and buy a block Subaru asks for build date if you are buying for an 06 model. IIRC, it was very late in the MY06 run that Subaru changed the design on the motor. Only a few 06 STIs were made that way. I could be crazy though and none were made with the newer block.
Subaru EJ257 STi Shortblock, JSC Speed
where do u find out our build dates?
beecha91 is offline   Reply With Quote
Old 06-17-2008, 11:41 AM   #47
Car: 06 STi
Says build dates of 7/06 or later which is the 07 model year block. Pre 7/06 build dates are 04-06 STi's. There's nothing new stated here. There are no 06 STi rollong around with 07 blocks from dealerships/SOA. The 07's have some slightly different tapped holes for the fuel rails which are top feed style. There are probably other slight differences in other mounting points.
Old 06-17-2008, 05:26 PM   #48
Fav Mod: sz49 8cm
ya I saw that I was asking where we find our build dates to see if im pre 07/06 or not, call soa? or a dealer? Thanks bro
Don-
Old 06-17-2008, 05:40 PM   #49
Car: 06 STI
Don-
It's on the little plate on the driver's side lower sill (when you open the door).
When does productions start? So if the end is July 2006, when did the 2006 production start?
oc1806STI is offline   Reply With Quote
Old 06-17-2008, 05:45 PM   #50
Fav Mod: sz49 8cm
Thanks didnt even know the build dates on the door tab. Im in the clear with 08/05
