IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Engine, Power, & Performance
Old 06-11-2008, 07:58 PM   #1
Fav Mod: Exhausssst
Send a message via AIM to SlowScooby
Default Cylinder number 4?
If you are looking at the motor from the front of the car do the cylinders go in this order?
3 4
1 2
So #4 would be the one in the rear of the engine bay, closest to the driver?
I have a misifre in that cylinder and I am gonna try and replace the coil....already tried replacing all the plugs and it didn't fix it.
SlowScooby is offline   Reply With Quote
Old 06-11-2008, 08:41 PM   #2
Car: 08 CBR1000RR
Fav Mod: None
Default Re: Cylinder number 4?
What mods are you running?
Old 06-12-2008, 03:25 AM   #3
Car: 2005 STI
Fav Mod: Methanol
yes, that is cyl 4.
I HATE YOU CYL 4
DIAF CYL 4
xrocket21 is offline   Reply With Quote
Old 06-12-2008, 06:44 AM   #4
Fav Mod: Exhausssst
-Invidia Downpipe
-HKS carbon Ti exhaust
-APS 70mm Intake
-APS 765DR FMIC
-Ported wastegate
-Forge WG actuator
-Forge BPV
-Cobb AP v1, protuned
-SS brake lines
-Walbro FP
I borrowed a buddys spare coil to try out this weekend.....Somehow I doubt that;s gonna work.
Do stock injectors go faulty?
I really hope the motor is ok......
Old 06-12-2008, 08:17 AM   #5
Originally Posted by SlowScooby View Post
Do stock injectors go faulty?...
Sometimes, yes. However, I'd first run a compression/LD test before I started swapping the injectors and coil packs. If nothing else, it eliminates the lower end from the problem solving list.
Old 06-12-2008, 08:23 AM   #6
Car: 08white sti gold bbs
Fav Mod: emblem delete
good advice
sleepsindirt is offline   Reply With Quote
Old 06-12-2008, 08:27 AM   #7
OpenSourcerer
Fav Mod: ECU
^^What he said. Missfires in #4 are often caused by a motor that has lost compression. I would want to eliminate that factor first.
Old 06-12-2008, 01:55 PM   #8
Fav Mod: Exhausssst
Ok, thanks guys. I guess I should schedule a compression and LD test.
Old 06-12-2008, 02:42 PM   #9
We'll keep our fingers crossed, amigo. Let us know the results
Old 07-16-2008, 09:14 AM   #10
Fav Mod: Exhausssst
Figured I would update for funnies.
I have a friendly local service writer/dealer and took it in there to get it checked out. Turns out it was a bad stock injector on number 4. I also managed to get a compression test done:
#1 - 148
#2 - 141
#3 - 149
#4 - 150
So cylinder #2 is a little lower than the others, but still looks in the good range to me. What do you guys think? I haven't gotten the misfire code running stock for about a week, I am gonna go stage 2 again and see what happens.
I plan on going 850 injectors with a 20g soon anyway, I just wanted to make sure the car was solid first.
Old 07-16-2008, 10:07 AM   #11
OpenSourcerer
Fav Mod: ECU
Not bad for an older car.
