Old 06-11-2008, 03:47 PM   #1
Car: Silver 04 sti
Fav Mod: Cobb stage 2
Default cobb ap 1 cel question
My sti was reading that it is too lean. wat does that mean?
Mydadssti is offline   Reply With Quote
Old 06-11-2008, 04:45 PM   #2
Car: 08 CBR1000RR
Fav Mod: None
Default Re: cobb ap 1 cel question
What mods do you have? What was the engine code? To lean means that it not reading enough fuel with an 02 sensor. The air to fuel ratio is not correct.
Sorry to go off topic for a min, but ...Whooohooo, 2300 posts!!
Old 06-11-2008, 04:56 PM   #3
Car: Silver 04 sti
right now i have a fmic, tbe, intake, m boost controller and cobb ap stage 2.
Dont i need to change my fuel pump to get rid of the code. It read PO171.
Old 06-11-2008, 05:09 PM   #4
Fav Mod: I do meth...
The FMIC isn't helping on the stock turbo.
The intake is throwing the code though. Get a protune or drop the intake.
renns is offline   Reply With Quote
Old 06-11-2008, 05:20 PM   #5
Car: obp07sti
Fav Mod: stg.2
my intake doesn't throw a cell. He needs a protune with a fmic. Can't use ots map with his mods.
cn07ob is offline   Reply With Quote
Old 06-11-2008, 05:34 PM   #6
Car: 08 CBR1000RR
Fav Mod: None
Ummm yea, those mods wont work with a Cobb stage two map. Why are you using a MBC? The Cobb maps use the stock boost solenoid to control boost. You aren't suppose to use a MBC. The FMIC isn't helping either. The intake might not be that bad, it just depends on which one you are using.
Old 06-11-2008, 06:45 PM   #7
Car: 06 WRB STI
Fav Mod: Stage 2
+1 for protune, and you should get rid of the boost controller
parsnipity is online now   Reply With Quote
Old 06-12-2008, 01:32 PM   #8
Car: Silver 04 sti
But my MBC is always all the way down. I dont really need much boost. I just keep it there in case i run with my nephews. SO its a protune that i need to get?
Old 06-12-2008, 01:43 PM   #9
Car: 08 CBR1000RR
Fav Mod: None
It doesn't matter if you have your MBC set all the way down. The Cobb maps are not setup for ANY aftermarket boost controllers. They are setup so that boost is controlled by the stock boost solenoid which is controlled by the ecu. You will continue to have problems until you decide to get a protune for your aftermarket mods that are beyond the limits of stage 2.
Old 06-12-2008, 01:44 PM   #10
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
take off the above stated. +1
Old 06-12-2008, 02:19 PM   #11
Car: Silver 04 sti
all right. ill go and take off the mbc. thanks everyone!
