Old 06-11-2008, 12:14 PM   #1
Car: Blue 07 WRX STi
Fav Mod: Stage II
Default After market exhaust headers + P&P intake manifold = ?
Well guys, I have an 07' STI with a DOM III, FMIC, Meth, injectors, etc., I'll be getting the car dyno-tuned in the near future. Before the dyno-tune though, I would like to add a few more mods to increase the top-end and flatten out the torque curve a bit without doing any major engine work. I already have a Grimmspeed EWG waiting to be installed, if that helps?... Will some exhaust headers and a slight P&P on the intake manifold do anything? This is about the only thing left before any major engine modifications, so that's why I'm asking if it's even worth it... Any suggestions? Thanks!
riggy30 is offline   Reply With Quote
Old 06-11-2008, 04:24 PM   #2
LSE
Fav Mod: Defi Gauges
Default Re: Exhaust headers + P&P intake manifold = ?
yes it will do something to your power curve which you will like. On stage 2 you get about 15-20whp. However, if you search, you'll find some dyno pulls that show how this gain is not just a peak value, but rather a nice increase across a pretty good rpm range. How much you'll gain is hard to say given you are so moded already. All the charts I've seen have been on the stock turbo.
the debate of P&P vs new headers is long and I kind of side on new headers given you can snatch a set of maddad or gt spec for 450 buck easily.
Old 06-11-2008, 04:48 PM   #3
Car: 08 CBR1000RR
Fav Mod: None
I'm sure you would have some decent gains with these mods. Do you have TGV deletes done yet?
I believe he was referring to a ported and polished intake manifold, not after market headers vs. ported stock exhaust header.
Old 06-11-2008, 05:10 PM   #4
LSE
u're right misread that one.
Old 06-12-2008, 04:51 PM   #5
Fav Mod: Stage II
[quote=ninjaboy76;1899440]I'm sure you would have some decent gains with these mods. Do you have TGV deletes done yet?
No, I don't have TGV deletes yet, as I heard they are not really worth it... Plus, they it makes the 07's run like crap on startup... Have you guys seen good gains with TGV deletes?
Old 06-12-2008, 05:05 PM   #6
Car: 08 CBR1000RR
Fav Mod: None
Default Re: After market exhaust headers + P&P intake manifold = ?
Well you sounded like you were looking to get the rest of the power out of your setup before you start looking into engine work. Thats why I suggested TGV deletes. I haven't seen any hard numbers from doing TGV deletes as opposed to not doing them, but they are probably good for around 10whp...maybe. They would certainly help eliminate flow restrictions.
Old 06-12-2008, 10:14 PM   #7
Fav Mod: Stage II
Thanks guys. After doing some more research, it seems like headers don't really make that much of a difference with larger turbos... Most, if not all tests that I've seen (header related) were on the stock turbo. Is anyone running after market headers with an EWG and a larger turbo? I would really like to see some numbers. Also, after seeing all those dyno-graphs, why the heck do we loose so much power up-top? It surely can't just be the turbo... Even the hp curve was dipping in the high rpm's... Man, subbies suck in the 5-7k rpm range... No wonder why we lose to EVO's all of the time
