Old 06-11-2008, 11:27 AM   #1
Car: 07 Impreza WRX STI,
Fav Mod: Track days!!!
Send a message via AIM to GoodTimes
Default Milky suff on rad cap....
I was doing my oil change today and i wanted to check every thing else so i wanted to see how my coolant was so i opened up my rad cap and found this.
and.
What could this be.
I just went stage 2 yesterday.
Thanks
Matt C,
GoodTimes is offline   Reply With Quote
Old 06-11-2008, 11:34 AM   #2
Fav Mod: Rustoleum Flat Black
Default Re: Milky suff on rad cap....
Are you running coolant in their Matt?
I run straight DI water and Water Wetter and get the same goo...
About time on that Stage II...LOL
grambo is offline   Reply With Quote
Old 06-11-2008, 11:36 AM   #3
Car: 2007 OBP STI with Go
Fav Mod: dealer license plate delete
interesting... maybe one weekend you can flush the system and see if there is a lot of particulate.
subscribed...
Kylipso is offline   Reply With Quote
Old 06-11-2008, 11:36 AM   #4
Car: 07 Subaru STi
Fav Mod: Coilovers/Tune
Send a message via AIM to IGoFast1589
Sorry to thread jack, but do you notice a difference with Water Wetter? Is it worth it?
IGoFast1589 is offline   Reply With Quote
Old 06-11-2008, 11:37 AM   #5
Yeah im running 50/50 mix and water wetter. so the goo is normal?
Old 06-11-2008, 11:39 AM   #6
oh thats probably not the best idea as water wetter is meant to be run with straight water.
but ive never seen the goo in any of the bikes ive run the water wetter, in only when mixed with reg coolant it forms a kind of scum.
Last edited by Kylipso : 06-11-2008 at 11:41 AM. Reason: longest run on sentence ever
Old 06-23-2008, 10:35 AM   #7
Its the difference of a few degrees. I think its some cheap HP. Though its likely a .010 of a horse or something...
Old 06-23-2008, 10:36 AM   #8
I had the goo until I flushed it completely. When I did my first change I didn't have a pan to safely flush it so I just said F it and put in the water and the pink stuff.
Old 06-23-2008, 10:38 AM   #9
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
FYI Matt. Your okay.
