Old 06-20-2008, 02:08 PM   #16
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
Default Re: Will putting in a cat-less DP fail me at emissions testing?
if you have an AP you can clear the CEL or get an mechanical cel elimination which spaces the 02 sensor an inch farther. Bottom line is if there is no CEL you will pass, at least here in NC
B4RSTiwsnc is offline   Reply With Quote
Old 06-20-2008, 04:03 PM   #17
Fav Mod: Invidia V3 DP with Greddy Ti-C exhaust
Send a message via AIM to BMGofUSMC
Hmmm noted. I do have an AP. Thanks. I may message you later for more specific questions on this.
BMGofUSMC is offline   Reply With Quote
Old 06-20-2008, 04:07 PM   #18
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
thread from the dead.
Old 06-20-2008, 06:08 PM   #19
Car: 05 OBP WRX STi
Fav Mod: Right Foot
Originally Posted by Fhqwhgads View Post
I don't think the Helix will gain CARB exemption or approval because it removes one of the cats (and I think it might change the location of the other one, although not 100% sure). I highly doubt the CA legislature will allow the removal of 1 cat because as of right now, even with the cat, the Helix is basically illegal. Of course if your state doesn't have visual you will probably be fine (and if it does have visual, you still might be fine but theoretically you should fail).
I generally agree with emissions rules. What I do not agree with is the whole visual aspect. As long as the car falls within the levels deemed appropriate, everything else should be irrelevant.
Correct, the Helix downpipe will never gain CARB approval because it eliminates one of the cats.
However, the Perrin downpipe is 49-state CARB approved. Guess which state isn't on the list?
atomicfire is online now   Reply With Quote
Old 06-23-2008, 11:52 AM   #20
Ummmm California???
