Old 08-06-2004, 05:59 AM   #1
Car: 2004 Subaru STi
Fav Mod: AMR BIG MAF
IWSTI Addict since: Jul 2004
how can i stop fuel cut?
i was going to get the turbosmart fuel cut defender but someone told me not to go that route,.
SuperSTi is offline   Reply With Quote
Old 08-06-2004, 06:04 AM   #2
Car: 04 WRB/G STi
Fav Mod: Sz49 + Meth
IWSTI Addict since: Jun 2004
Stop boosting over 17.5 psi.
Boostpimp is offline   Reply With Quote
Old 08-06-2004, 06:07 AM   #3
actually im running at 19psi right now and i have no boost cut whats so ever. as soon as i hit the 20 spot then it happens. i want to boost over twenty. what should i do to get ride of boost cut.
Old 08-06-2004, 06:28 AM   #4
Car: 05 Subaru WRX STI CG
IWSTI Addict since: Aug 2003
If you are boosting over 17psi on the stock EM you are going to kill your engine. That is definitely not smart and I know Dan @ Godspeed can tell you of all the people w/ blown engines that have done this. Get a UTEC or something before you do serious damage. The turbo is out of its efficiency range by 20psi anyways and you're just blowing hot air and damaging your engine. The timing on the stock ECU is too erratic to run that much boost. The only way to eliminate the fuel cut is by using the HKS or similar FCD (fuel cut defencer). However if you want to blow yourself up thats the ticket... strap that in and 20psi and you'll be going forged internals in no time... So im sure as anyone will tell you... get EM.
Robert~
