Old 06-09-2008, 09:43 AM   #1
Default Fuel Filter
So what is the conclusion on the whole fuel filter topic for the STI? I've read a few threads on here and Nasioc and some say 90K, others say skip it, and some say replace it at 60K. In the manual it says its recommended at 60K and should be replaced at 120K.
For those of you past 60K what have you done? I just got my 60K maintenance done and this is the last thing I may have to do. I wonder if I should just leave it and do it at 90 or 120K.
Any input would be appreciated.
freeze is offline   Reply With Quote
Old 06-09-2008, 12:31 PM   #2
Car: 05 WRB Sti
Fav Mod: Stage 2
Default Re: Fuel Filter
i would like to know as well
ezsleeper is offline   Reply With Quote
Old 06-09-2008, 03:51 PM   #3
Fav Mod: sz55 external wastegate
I did mine around 60k but I installed a fuel pump at the same time, if you plan on upgrading your fuel pump that would be the best time. It's not hard to do just relieve your fuel pressure over night. The whole assembly comes up from the trunk/ back seat area with a little twisting action.
Mycues1982 is offline   Reply With Quote
