Old 06-08-2008, 01:05 PM   #1
Car: 06 STI Black
Fav Mod: Radar Detector
Default Removing MBC?
Hello, I am looking to remove the boost controller valve from my 06 STI. I have the origional hosing and can easily see where two of the 3 connections go. One to that actuatator, and the other to the turbo. The one that I cannot find a home for is the one at the bottom of the plastic "T". It has a plastic push on connection to it ready to accept another hose. Where does this 3rd connector go?
Everything I read about these make me a bit paranoid about leaving this thing on without a tune. So, its comming off.
The downpipe and intake I think are ok for now.
Thanks
BEEAH is offline   Reply With Quote
Old 06-08-2008, 01:39 PM   #2
Car: 07 SWP STI LTD #484
Fav Mod: Defi Gauges
Default Re: Removing MBC?
It goes to the Turbo inlet hose. Here is a couple pics:
close up
Intake
gr00vy07 is offline   Reply With Quote
Old 06-09-2008, 01:53 AM   #3
Car: 04 WRX Wagon
Fav Mod: EvoIII 16G
Thats not how that hose is spose to be that spot is for the linkage cable for the tb
Otherguy is offline   Reply With Quote
Old 06-09-2008, 05:53 AM   #4
Car: 08 White STI
STI's have DBW throttle body's not cable driven. Plus Subaru(nor any car manufacturer) would EVER put a throttle cable on a flexible hose. Do you know how dangerous that would be? Hose flexes, throttle changes.
In response to the original question. One part of the T goes to the wastegate actuator, the other goes to the turbo compressor outlet, and the third part of the T goes to the factory BCS which should be attached to a bracket bolted to the passenger side shock tower.
rjacobs is offline   Reply With Quote
Old 06-09-2008, 06:06 AM   #5
+1 . my pics showed the hose coming out of the BCS to the intake which you will need to install anyway. I forgot to mentioned or take a pic of the T junction to the BCS hose.
Old 06-09-2008, 08:17 AM   #6
Car: 04 WRX Wagon
Fav Mod: EvoIII 16G
Rjacobs this is Stupidfastwagon from Nasioc...
Look at this picture and tell me what you think :S
Im not crazy that spot on the intake arm is for the cruise control cable...
Old 06-09-2008, 08:33 AM   #7
Teh Other White Meat
Trader Rating: (22)
you are correct sir. /hijack
Old 06-09-2008, 08:37 AM   #8
Car: 04 WRX Wagon
Fav Mod: EvoIII 16G
I knew I wasnt crazy... I had to remove that line when I went to a MBC and just stuck a bolt in the hose :P So far so good
Old 06-10-2008, 05:20 PM   #9
Car: 06 STI Black
I did find it, thanks guys. It was a hose comming from the left side of the wall.
