Old 06-08-2008, 11:26 AM   #1
Car: 07 WRB STi
Fav Mod: None Yet
Default Check Engine Light On.... Cruise Control Light Flashing
My check engine light is in on the and cruise control light is flashing. The car has been driving fine. Can anyone help me with what can be the problem?
07StiMIA is offline   Reply With Quote
Old 06-08-2008, 11:35 AM   #2
Car: CMG 04 STI
Fav Mod: AP FTW
Send a message via AIM to twozzracer
Default Re: Check Engine Light On.... Cruise Control Light Flashing
O2 sensor mod? Do you have an aftermarket downpipe?
twozzracer is online now   Reply With Quote
Old 06-08-2008, 11:39 AM   #3
Car: 06 Subaru WRX STI
Send a message via AIM to dukenukem
Go to autozone and get them to pull the code. Then search what the code is for. Fix the problem as needed.
dukenukem is offline   Reply With Quote
Old 06-08-2008, 12:05 PM   #4
Car: 07 WRB STi
Fav Mod: None Yet
I have a CTB but stock DP......I have an autozone across the street from my house. I will go and then look up the code here. Thanks
Old 06-08-2008, 02:48 PM   #5
I had the same thing happen to me last week. Turns out my stock airbox cover wasn''t closed over the filter properly and the car threw a CEL.
Old 06-08-2008, 07:32 PM   #6
Car: 2007 swp sti
thats funny i took the air box silencer out today then tried to the the drl disable cut the green wire with the yellow stripe and i have the same thing. i figured it was the wire cause the drl are still on!!!! so pissed last time i ever cut any wires!!!!
wantsti118 is offline   Reply With Quote
Old 06-09-2008, 07:53 AM   #7
Car: Blue STi '06
The dealer told me the cruise light always flashes when CEL comes on. (Can anyone verify this?)
CEL light coming on means there is a error code posted in the ECU. If you have the accessport, read the code to see what the problem is.
idrivearocket is offline   Reply With Quote
Old 06-09-2008, 08:12 AM   #8
Car: The Vroom-mobile
Fav Mod: JDM Gears
correct
