Old 06-03-2008, 07:22 AM   #1
Car: 05 Subaru WRX STi
Fav Mod: none
Default Help, white smoke at idle
I have been researching how long it takes for the smoke to stop after a TBE install and have run across numerous threads stating things such as blown turbo seals and headgaskets. I am now a little worried but hopefully for no reason.
Last week I installed a TBE(no-cat) and flashed stg2 93 AP map. I used lithium grease on the new bolts and used alot of PB blaster on the original bolts to get them off. I expected it to smoke for a couple days but it almost seems like its getting worse after a week. The car doesnt smoke at startup and will only smoke when its warmed up and left to idle at a red lights etc. Its white smoke and doesnt smell sweet or like oil(to me at least) and when I accellerate from the stop it blows a big puff out and then quits smoking untill the next stop/idle situation. Im not sure if its important or not but I have not re-installed the heat sheild and I didnt put any wrap on the downpipe. No other modifications have been made to the car and it seems to be running very strong. Is it normal to smoke for this long(1 week, ~150mi) with a new TBE or is this something I should really look into?
Thanks in advance for your help.
stugry is offline   Reply With Quote
Old 06-03-2008, 08:30 AM   #2
Car: 04 sti
Fav Mod: enginuity tuned
Default Re: Help, white smoke at idle
possibly a turbo seal.
Old 06-03-2008, 08:58 AM   #3
Fav Mod: none
it just seems way too coincidental to have blown a turbo seal right after installing the tbe. Unless of course the increased power blew an already weakened seal. Is this something that happens often to people that go stg 2? What is it that causes the seal to blow? I havent noticed boost creep but if I was experiencing creep would that blow it?
Old 06-03-2008, 09:07 AM   #4
Car: 04 sti
i think it's just an issue of time and mileage. i get a little bit of white smoke on a cold start but it goes away after the car warms up. i don't recall seeing any white smoke coming from my exhaust after a tbe install, but then again i haven't bought a brand new tbe before. it could also be extra material on the gaskets burning off.
at least it's white and not blue smoke
Old 06-03-2008, 09:21 AM   #5
Fav Mod: none
definitely not blue. I guess if its a turbo seal then the wife cant argue when I NEED to upgrade the turbo to fix the problem. As long as its not the engine causing the smoke then it should all end well.
Old 06-03-2008, 10:14 AM   #6
Fav Mod: none
nobody else has any input?
Old 06-17-2008, 12:23 PM   #7
Fav Mod: none
ive tried a few simple things to end the smoking but its still there. Im preparing for a turbo upgrade but before I go that route I would like to make sure thats the cause. Is there any way to test for bad turbo seals. Ive removed the DP and looked inside the turbo and took some pics but I dont really know what im looking for. I dont know how to post pics on here but it does appear that there is some oil/residue on the ousides of the fins if that is any idication of a bad turbo. Ive found various tests to rule out engine internals and that all seems to be fine which makes me more confident that it is the turbo. I just dont want to plan a turbo upgrade around a bad engine or some other issue. Im lookng for a decent local shop to get a leakdown and compression test to be even more confident if anyone knows of one near me in the N. Ky or Cincinnati area.
Thanks in advance for any input.
Old 07-21-2008, 07:44 AM   #8
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
I had a compression check done 2 months ago and everything checked out fine and leakdown was 4%. Blue smoke came out today out of the middle of nowhere when I was at idle, however nothing came out when I was driving since I had someone behind me. Then when I got to the shop again blue smoke started to come out! I thought it was the turbo seal, but the car has 62k miles protuned stg 2. Oil was changed 1.5k miles ago. PLEASE HELP! I really hope the motor is not gone since it drives fine, and the compression test checked out 2 months ago.
B4RSTiwsnc is online now   Reply With Quote
Old 07-21-2008, 11:32 AM   #9
Car: 07 STI
take off your bov from the tmic and see if there is oil in the intercooler. if there is take off your intercooler and clean it real good. also check your oil level perferberly letting it sit over night and checking it in the morning to make sure your not overfilled causing oil to get burned and having blue smoke. you would proberly have a light film of oil in ur intercooler but if there is alot and you ur oil level is low i would think it would be your piston rings being broke. hope this helps you out man.
Rey
weasel936 is offline   Reply With Quote
Old 07-21-2008, 12:46 PM   #10
its the turbo going bad, no oil in the intercooler, and the oil level is fine. Turbo has shaft play and a crack over the wasteagate
