Old 06-02-2008, 10:02 AM   #1
Car: 2007 STi
Fav Mod: kung f00 skillz!
Send a message via AIM to enoxard
Default 2007 Mod Path Sanity Check PLS!
I am currently at stage 2 and looking to add a few things before i go in for the first tune. ive been debating meth vs turbo upgrades and decided to start with meth with plans of a turbo upgrade in the future.
Car
2007 STi
Current Mods
Cobb Stage 2
K&N Drop In
Proposed Mods
Aquamist HFS-5 Injection Kit
-1 Colder Plugs
Walbro 255 Fuel Pump
740 DW Injectors
APS 70mm CAI
APS Turbo Inlet
MADDAD V2 Velocity Coated Headers and Up-Pipe
Turbo Heat Shield
Thermal Coat Downpipe
Tune
I am hoping someone can run a sanity check on my list and point out anything that makes no sense or suggest an improvement.
daily driven.
thanks.
enoxard is online now   Reply With Quote
Old 06-02-2008, 10:10 AM   #2
Fav Mod: Driving School
Default Re: 2007 Mod Path Sanity Check PLS!
I would nix the meth setup and save for a turbo upgrade.
Especially for a daily driver where reliability is of top importance; meth is a losing proposition. Adding another whole system that the engine depends on to live a long and healthy life is not ideal from a reliability standpoint.
MartinSTi05 is offline   Reply With Quote
Old 06-02-2008, 10:28 AM   #3
Car: 06 Aspen/gold STi
Fav Mod: Whatever I buy next
so your running stage 2 mapping on a stock 2007 w/ a drop in air filter?
C.J. is offline   Reply With Quote
Old 06-02-2008, 10:38 AM   #4
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
go with the meth, turbo inlet, header of choice, intake, walbro / injectors.
it will be one insane street car without a new turbo.
Old 06-02-2008, 11:12 AM   #5
Car: 04 WRB STi
Fav Mod: Hydramist + GT52
Send a message via AIM to RemlapaN
FMIC + Stock turbo = Silly imo.
RemlapaN is offline   Reply With Quote
Old 06-02-2008, 11:38 AM   #6
Car: 2007 STi
in addition to a cobb dp and cat back.. didnt think i had to line item stage 2 =/
thats what im hoping.. at least to bring back the after the edge of the stage 2 upgrade is starting to dull.
is there a good reason to go with an aftermarket manifold as opposed to port, polish, and coating the stocker?
understood. with the turbo upgrade in the future, an FMIC will be required. i could put this off until i upgrade the snail. that probably makes more sense.
Old 06-02-2008, 12:06 PM   #7
LSE
Fav Mod: Defi Gauges
i'd leave the fmic out until you can do the turbo.
Old 06-02-2008, 12:26 PM   #8
Car: UGM STI LTD
Fav Mod: Invidia G200
Send a message via AIM to XDCSTi
Sounds like you got it all planned out.
I would leave off the Meth and FMIC till you can get a bigger turbo since they really aren't needed for what your doing now.
Also the I would check out the MadDad V2 Headers...I have seen those things Jet Coated in person and they are a work of art. I have also heard of good numbers from using them.
With all those mods and a good protune your car will put a little more than a smile on your face...
Let us know what numbers you make...
XDCSTi is offline   Reply With Quote
