Old 06-01-2008, 10:31 PM   #1
Car: 98/04 RSTi
Fav Mod: gt spec header & Invidia G200
Default no problem now...thanks
thanks.......
stiboss is offline   Reply With Quote
Old 06-01-2008, 11:18 PM   #2
Fav Mod: Ricer Flyby
Default Re: 04 sti stage 2 no yet tune, motor rattles
im kinda confused by ur title. So you put on headers, up pipe and downpipe, but do you have an accessport? if not then those codes are the catless codes and you deff shouldnt drive your car more than you absolutely have to until u get a tune. In fact I wouldnt drive it at all untill u flash it to stage 2 with the accessport
Old 06-01-2008, 11:23 PM   #3
Car: 98/04 RSTi
oh ok.. i dont have accessport....i just had the hardware setup
Old 06-17-2008, 08:54 PM   #4
Car: 98/04 RSTi
now i got the accessport v1 setup....loaded the stage 2 map....but the motor still rattles...help please?
Old 06-17-2008, 09:01 PM   #5
Car: 07 SWP STI
Fav Mod: Blouch Dom 3R
Send a message via AIM to Turbo_Joe
Exhaust leak? Check all the bolts. Check any heat shields you might have, maybe they're loose. An exhaust leak can cause popping and rattling. That's all I have for the rattles, as for the rough idle, good luck!
Turbo_Joe is offline   Reply With Quote
Old 06-18-2008, 03:38 AM   #6
Car: 2000 RSTi
Send a message via AIM to fusionchicken
did you cut your stock downpipe heatshield and put it back on without putting all the screws back on? my rsti has a rattle from the engine sometimes but it's the head shield...
bad motor mount? have somebody sit in the car and rev the engine while you stand there lookin to see whats moving...
fusionchicken is offline   Reply With Quote
Old 10-05-2008, 07:32 PM   #7
Car: 98/04 RSTi
Default Re: no problem now...thanks
it was one of coil pack went bad causing the missfire..thanks alot
