Old 06-04-2008, 01:09 AM   #16
Car: 06 Subaru STI
Fav Mod: DomTune
Default Re: Help! Car won't start after 6th gear pull...
check your fuel filter, ive had a similar problem as i was driving and shut off(ended up finding that the high pressure fuel pump that i had which was a walbro had caused the rubber oring to slightly pop out which caused it to lose fuel pressure. check the fuel filter that sits ontop of the fuel pump (not the sock filter on the bottom of the fuel pump)you can take it apart by twisting the two halfs and check for the correct seating of the oring hope this helps
ArizonaSTI is offline   Reply With Quote
Old 06-04-2008, 05:02 AM   #17
Car: WRB 05 WRX STi
Fav Mod: GT30R
Send a message via AIM to terje9126
Thanks for the advice! Will check that filter out asap!
terje9126 is offline   Reply With Quote
Old 06-12-2008, 09:10 PM   #18
Car: 01 Turbo IS300
Fav Mod: My large chinese nutsack dangling furiously
Send a message via AIM to SophieSleeps
And the car still sits there. Covered in pollen.
SophieSleeps is offline   Reply With Quote
Old 06-13-2008, 06:49 AM   #19
OpenSourcerer
Fav Mod: ECU
Your injector driver circuit has failed I bet. Pull an injector and hold it AWAY from the engine when plugged in. Start it. Alternately, use a voltmeter on the the injector plug itself.
Old 06-15-2008, 08:32 AM   #20
Car: WRB 05 WRX STi
Fav Mod: GT30R
Ended up being the O-ring in the fuel filter...
Thanks for all the input everyone!
I'll post a pic up of the stupid O-ring and how it was when I found it.
Old 06-15-2008, 08:47 AM   #21
Car: Silver 08 STI
good to hear its fixed
jrdriller is offline   Reply With Quote
Old 06-15-2008, 06:34 PM   #22
Car: 06 Subaru STI
Fav Mod: DomTune
good to hear that u found it, i would still buy a new one still to be safe
Old 06-15-2008, 08:17 PM   #23
Car: WRB 05 WRX STi
Fav Mod: GT30R
Heading to Subaru in the morning Thanks again for the the advice!
Old 06-18-2008, 04:47 AM   #24
Car: WRB 05 WRX STi
Fav Mod: GT30R
If you look closely, you can see that the o-ring is coming out. That's how I found the filter. Everything is fine now, car is back up and running! Thanks everyone!
