Old 06-01-2008, 02:53 PM   #16
Fav Mod: Perrin 30r Kit
Default Re: Is going FMIC a good idea?
like ninjaboy said, i'd gather the parts and make sure you have extra cash laying around. its not cheap to start doing bigger upgrades.
Old 06-01-2008, 06:28 PM   #17
Car: '07 STi Limited #482
Many people have done the FMIC with the stock turbo thing, and it will work, and you will have power. Thing is, our turbo doesnt flow enough air and takes longer to fill the larger space of the FMIC + piping. This causes boost lag.
There is a certain amount of tuning that can be done to reduce this.
If it were me, and I was definitely about to buy an FMIC, I would put it on with the stock turbo. After enough playing around with it, if it totally sucked, I would just switch back until I got the bigger turbo. I dont think it would be that bad though.
Old 06-01-2008, 06:38 PM   #18
Car: 08 CBR1000RR
Fav Mod: None
Originally Posted by STIstud2k7 View Post
So when I get a fmic, I won't get heat soaked, right?
Even with a FMIC you can still heat soak. Any intercooler can heat soak in stop and go traffic, but once your moving again, it will cool back off. I would venture to say that the only time an intercooler can heat soak while on the boost is when the turbo becomes to large for the intercooler to keep up.
ninjaboy76 is online now   Reply With Quote
Old 06-01-2008, 07:08 PM   #19
Car: Blue w Gold 07 WRX S
Fav Mod: Tune
what is the BPV? Is it the bypass valve? Do I need one with the kit? Is the CSSPerformance fmic kit good quality product?
STIstud2k7 is offline   Reply With Quote
Old 06-01-2008, 07:27 PM   #20
Fav Mod: GT35R 450+WHP Pump No Meth
Originally Posted by WESTI View Post
Be careful with the CSS performance one. I paid for mine 2 wed. ago and its still not here. U should read the nasioc vendor review area
That sucks, I was just give him so ideas for a mid grade FMIC. It sounded like he on a budget but I personally go with a APS, I have the 725 but they also have the 525 just a slightly smaller core. Many vendors on here carry many product lines, search them on the vendor sales forums and go from there. Check out APS site:Subaru STI Performance
Old 06-02-2008, 12:39 AM   #21
Car: 2000 RSTi
Send a message via AIM to fusionchicken
yup...my old Evo 9 was no fun in 100+ degree weather...the lag esp. off the line in 1st gear drove me NUTS sometimes lol
fusionchicken is offline   Reply With Quote
Old 06-02-2008, 12:39 PM   #22
Fav Mod: Stg. 2
From first hand experience, the Ebay FMIC core isn't bad at all it's the piping fitment that is the big issue.
Tweeter is offline   Reply With Quote
Old 06-02-2008, 05:26 PM   #23
I believe this is probably true. The temp difference between a large IC and the stocker on the stock turbo is probably not much in most situations. You probably would stand to gain a little off the temp, however, and some from having a better flowing design. On the track the difference would probably be more apparent though.
