Old 06-03-2008, 08:49 AM   #31
Car: R14
Fav Mod: twinscroll turbochargers
Default Re: Full-Race Twinscroll 35R testing -- modified magazine tuner shootout (5/24)
Originally Posted by LittleBlueGT View Post
15 psi by 3,000 on an engine that is not stock, right. I want 15 psi or better on an internally stock engine (not in 4th or 5th gear either, in 3rd). I am waiting. Thanks for the up-dates.
dynoplot of our twinscroll 35R kit at 21 and 23 psi boost - 15 psi by 3000 rpm, 440 lbft by 4000 rpm and 496whp at 6500 rpm. fuel used was a mixture of 91 octane az crap gas and 100 octane unleaded from the pump
this motor was not stock, its a cosworth longblock. the main difference between it and a stock motor was the heads were ported and it has cosworth cams. The bottom end is obviously stronger than stock, but that doesnt make any extra power or spool the turbo any faster. A dyno of twinscroll 35R on an internally stock engine is coming at the end of this week/beginning of next
note how early and vertically the torque curve climbs to full boost, 200whp & 200wtq gain from 3000-4000rpms
Full-Race.com is offline   Reply With Quote
Old 06-03-2008, 09:09 AM   #32
Car: 04 sti
Fav Mod: enginuity tuned
what's with the dip @ 4500rpms?
and you guys need to post better (longer) videos!
Old 06-03-2008, 09:28 AM   #33
Car: R14
car was not fully tuned, ignition timing was wayy conservative since we were running crappy fuel. we will have a cleaned up fully tuned dynoplot to post in 1-2 more weeks. ill see what i can do for some better videos
Old 06-03-2008, 10:19 AM   #34
Car: 05 Subaru LGT
The dip is boost dip (right after the small boost spike), the tuner probably used OEM spec turbo dynamic tables, and need to find out what works best for this TS set-up.
FR:
I would have to say I am very impressed. I would absolutely love to see this dyno overlaid on a stage2 STI or anything else that we can compare it to (20g, green, etc.....) I know that won't tell us the difference in transient response, but it will tell us something......boost threshold.
I can't wait now to see a 3071, or even a 3076 TS plot!!!!!!!!
LittleBlueGT is offline   Reply With Quote
Old 06-03-2008, 05:05 PM   #35
Fav Mod: Driving School
Looks great Geoff!
MartinSTi05 is offline   Reply With Quote
Old 06-04-2008, 08:40 AM   #36
Car: 04 sti
awesome numbers btw!
good luck with the car
Old 06-04-2008, 10:03 AM   #37
an old tired whore
Fav Mod: myself
Send a message via MSN to kwlsti
crossing my fingers, i SHOULD! have dyno plots up with the full kit and a gt30r-ts on Monday... i HOPE!
kwlsti is offline   Reply With Quote
Old 06-04-2008, 10:41 AM   #38
Car: 2005 STI - obp
Do you have the 3076 or the 3071?
michaelc is offline   Reply With Quote
Old 06-04-2008, 10:52 AM   #39
Car: Car Builder
Fav Mod: Boost
Send a message via AIM to token-negro Send a message via MSN to token-negro
What struts were on that car? Motons?
token-negro is offline   Reply With Quote
Old 06-04-2008, 11:01 AM   #40
an old tired whore
Fav Mod: myself
3071, but i'll have to double check the box when i go to the shop.
Old 06-04-2008, 07:29 PM   #41
Car: 05 Subaru LGT
Please, please, please.
Full write-up.
Please log MAP, and g/s (hopefully both new and old tune are very accurate in the MAF scaling dept) before and after the tune on a flat road, same elevation.
Also record the temps.
Pleas get as much before and after data, it is important!!!!!!!!!
Old 06-04-2008, 09:44 PM   #42
Car: 05 Subaru STI
no wonder why you guys did so well, thats a pretty stout powerband.
looks like you're getting 300 wtq before 3500 rpms. thats pretty impressive.
Illusive is offline   Reply With Quote
Old 06-05-2008, 06:00 AM   #43
an old tired whore
Fav Mod: myself
well if you look in my journal you'll see what i have on the car, it's not exactly stock, and I'm not running a MAF. but i will post as much as i can/have.
the car fired up yesterday, we had a few injector leeks , but thats all fixed now. hopefully Mike from Innovative tuning will be in on Friday.
Full write-up.
Old 06-08-2008, 03:31 AM   #44
rxw
Car: 01 Subaru WRX STi Sp
WOOOOOOOOHOOOOOOOO..... finally some fullrace TS35r dyno's...... ITS freaking awesome! Love the spool and power..... great chart!
rxw is offline   Reply With Quote
Old 06-08-2008, 06:17 PM   #45
please get some in car footage especially of the dash while doing pulls.
shabib67 is offline   Reply With Quote
