Old 05-21-2008, 09:34 PM   #1
Car: 06 OBP STI
Fav Mod: DP!
Default Funky spool sound
Ever since I got this stromung shorty Dp installed on my 06 STi, the turbo spool sounded funny. The funny spool sound is off and on too. The more I think about it, it might only happen when the car is cold. The shop that installed it used new gaskets I got from the dealership. I have also removed and reattached the CB while looking for leaks.
Here is a clip of the funky spool sound...
http://www.fileden.com/files/2006/7/7/113945/Movie.wmv
And here is another one 5 mins later. Now it sounds normal...
http://www.fileden.com/files/2006/7/...Movie_0001.wmv
Im just worried this isnt a good sound. Anyone have any thoughts?
ramman949 is offline   Reply With Quote
Old 05-22-2008, 09:23 AM   #2
Car: 06 OBP STI
Fav Mod: DP!
Default Re: Funky spool sound
anyone bump?
Old 05-22-2008, 02:39 PM   #3
Car: 06 Subaru STI
Fav Mod: DomTune
try checking the downpipe bolts ( the tightness) also check your up pipe and header bolts sounds like a leak, most of the time you can tell where the exhaust leak is when there is some black soot around the flange
ArizonaSTI is offline   Reply With Quote
Old 05-22-2008, 03:02 PM   #4
Fav Mod: ohlins w/RCE springs, sz55
Send a message via Skype™ to elirentz
^if not that check your bov, turbo, intercooler hose, etc
elirentz is online now   Reply With Quote
Old 05-22-2008, 08:25 PM   #5
Car: 06 OBP STI
Fav Mod: DP!
Well, the sound just comes and goes now. Ive talked about it all day over at Nasioc with no solution found yet. So im taking it in to a local suby shop.
Old 05-23-2008, 04:00 PM   #6
Car: 06 OBP STI
Fav Mod: DP!
My local suby shop Garage Tuning found the issue. My stock UP gasket was leaking. Problem solved thanks to Kevin at Garage Tuning.
