Old 05-20-2008, 03:46 PM   #16
Fav Mod: APS DR725
Default Re: Smartest way to achieve 400 whp
You should DEFINATELY consider getting a new ACT/EXEDY clutch. I hit 400 awhp with a TD06 20G with meth, and my stocker started to slip on the dyno
bulletSTI is offline   Reply With Quote
Old 05-21-2008, 03:12 PM   #17
Riz
Thanks for all the input.....too many options with these cars
Looks like Im going for a full Megan Racing exhaust (UP, DP, Header,Cat Back) and a Stage 2 AP.
Then I need to work on pump, injectors and a quick spooling turbo that can reach 500 HP or so. I dont really dig the idea of the FMIC, but it looks like a necessary evil.
Riz
Riz is offline   Reply With Quote
Old 05-21-2008, 03:15 PM   #18
Send a message via AIM to jermdeez
I've got about 400whp on race gas with my green @23.5 psi, keep in mind a stock sti reads 215-220 on this dyno. I've got 70mm intake, fmic, EWG, (ewg is probably the best mod in the world) blah blah........shouldn't be too hard.
jermdeez is offline   Reply With Quote
Old 05-21-2008, 04:25 PM   #19
Fav Mod: stock clutch
I run just about 400whp on crap 91 oct with 850 cc pe injectors on my 30r
oce420 is offline   Reply With Quote
Old 05-21-2008, 04:49 PM   #20
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
Riz
I your goal is 500WHP then we are talking a whole a diff thing then a 400whp setup. Just so you know
Old 05-21-2008, 04:51 PM   #21
Riz
I think I will stop at 400, I just want the components to be able to grow with the car. I figure 400 is 'safe' then I will build a shortblock after that.
C.
Old 05-21-2008, 05:06 PM   #22
Car: 06 STI / STG 4
C.
Yeah man look into a Blouch Dom 3.0R or the GT 52 and all the supporting mods and you will get the 400+whp your looking for.. I just went with a dom 3.0r and METH I run a APS TMIC, my goal is for 500+whp with a TMIC def with a built shortblock from AR Fab.. Good luck LMK if you need any help..
Carlos
Old 05-21-2008, 05:16 PM   #23
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Originally Posted by BillFromTR View Post
Any 50 trim + meth will take you there.
/End thread
Old 05-21-2008, 05:17 PM   #24
Enginerd
Fav Mod: Tuning
Carlos
ha, you're going to make 500 with that turbo? Maybe with some C16 and some meth. That's a big number for that turbo. 500 WHP is a **** load of horsepower.
Old 05-21-2008, 05:42 PM   #25
Car: 06 STI / STG 4
YUP....
Old 05-21-2008, 07:53 PM   #26
Car: 04 WRB STI
Fav Mod: vf36
850cc is the largest injector for sidefeeds, you'll have to switch to top feed fuel rails and tgv's for larger top feed injectors. If you use Deatschwerks fuel injector calculator @ 80% max injector dutie cycle with 500 hp at the flywheel it calculates to 78.1 lb/hr or 820.3 cc injectors.
calisti is offline   Reply With Quote
Old 05-22-2008, 02:48 AM   #27
Car: LR 2008 WRX STI
Fav Mod: Bigger Turbo
Can you modify the stock 07 and 08 top feed injectors to flow about 900cc?
Rotated is offline   Reply With Quote
Old 05-22-2008, 03:30 AM   #28
Car: 04 WRB
Fav Mod: Greddy TI-C
Buy a Z06 Corvette or what these guys said.
Old 05-22-2008, 03:39 AM   #29
Car: aka - DownSTi
Fav Mod: Big Thanks to Jeremy @ Crucial Racing and ED @ EQ - Tuning
put it on a very very high reading dyno.. and load it even really high
i think bone stock 04 05 06 07 can do 400whp.. not sure about bone stock 08 STi tho
13onesti is online now   Reply With Quote
Old 05-22-2008, 03:51 AM   #30
Car: 07 STI OBP
Fav Mod: NUR SPEC R, 57maximum t/a,300 shot nitrous, dual carb, ITB,
im thinking about
sz49
750inj
aps cai(70mm)
exedy stg2 or ACT clutch
walboro pump
gt spec uel headers w uppipe
perrin stealth FMIC
should be close to 400whp
