Old 05-16-2008, 12:26 PM   #1
Fav Mod: SR55
Default Weird Squeeking noise, need advice
Hi everyone,
I need help diagnosing a peculiar squeaking noise that seems to be coming from the crank pulley of the serpentine belt. Oddly, the crank pulley seems to wobble at idle, which is when I hear the noise(its like a pulsing squeak). Once you rev the engine slightly, the pulley straightens out and the noise stops. I pushed on the pulley and it doesn't seem to be loose, but maybe it is. Im hoping I may just need a new belt but it seems to be in good condition. I have 65000 miles on the car and my mods are in my sig. Aside from the squeak the car seems to run really well. Any thoughts or help is appreciated.
******Update*******
Well everyone get this. I diagnosed the problem to be a completely demolished stock crank pulley. Basically the outer pulley separated from the rubber harmonic damper portion, completely deforming the pulley. This obviously threw all the belts off alignment, causing the squeaking and ruining a couple of belts. I really dont know what caused this but I need to get a new crank pulley. I know that the stock pulley will dampen vibration, but quite frankly I didnt seem to hold up well. Anyone have any suggestions for aftermarket pulleys? Doesnt AR Fab make an aftermarket harmonic damper? Thanks.
Brettnrs423 is offline   Reply With Quote
Old 05-17-2008, 09:45 AM   #2
Fav Mod: SR55
Default Re: Weird Squeeking noise, need advice
nobody????
Old 05-17-2008, 11:31 AM   #3
Car: 06 sti
Fav Mod: tbe
Send a message via AIM to SoflaSTI
well what time of pulley is it?
Edit: im guessing your pulley was install right. If it wasnt then you would have a world of problems. I would just check it to make sure its tight. Couldnt hurt
SoflaSTI is offline   Reply With Quote
Old 05-17-2008, 11:32 AM   #4
Car: 06 sti
Fav Mod: tbe
i just got my pulley installed and it does the same thing. My tuner said that the pulley is kind of glazed (shiny) and the belts might make some noise until it wears down a bit.
