Old 05-18-2008, 10:16 PM   #16
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
Default Re: upgrade turbo but also scared
Originally Posted by monito View Post
Explain to me cause I dont understand what youre trying to tell me (sorry My english is not so good).
Somebody told me that if I wanted a rotated turbo I will need a kit because the turbo inlet is not gonna be under the manifold. It gonna be next to it. Then the downpipe is not gonna match with the turbo output (i dont know how to say it in english) because the position is different. Is that right or he is lying me
I am not saying they are lying, but they gave you the wrong info.. If you want to run a stock location Turbo like the GT 52 the parts you have will work with that Turbo. Like Kit said its not a rotated setup check out the link he gave you.
The GT52 is a great Turbo look at the power Bragging section and you will see results for it..
Old 05-18-2008, 10:21 PM   #17
Car: 06 STI / STG 4
so gt52 I guess is a garret. What do I need to install this turbo
The GT52 uses a Garret Housing, its a GT3076. what you need well depends on what you have already. What mods do you have on your car right now.
Also you mean Lag not Lack... The GT52 is a good Turbo you can make pretty decent power on lower boost then some others and the spool up is pretty good but that depends on your tune aswell so we need more info brother... Where you from??
