Old 05-28-2008, 11:39 AM   #76
Car: CGM 05
Fav Mod: IAG 38mm EWG
Send a message via AIM to 1loudsti
Default Re: No Oil cap more horsepower
wow! thats really strange that they would do that....i wonder if there is a way to fix that
1loudsti is offline   Reply With Quote
Old 05-28-2008, 12:24 PM   #77
Car: 07 STI OBP
lol i just got my cobb loil cap so im gonna mod my old one. i think im gonna put one of those breather filters on top of it. see if it make a difference. ill only leave it for like 5min tho. i have an 07.......
Old 05-28-2008, 03:33 PM   #78
Car: 05' STi CGM/Silver
Fav Mod: Recaro Sports
I can only assume the reason they did that was to reduce the amount of oil getting blown into the intake. In the pictures its easy to see why it cant keep up.. But I still want some proof to see actual numbers that show a noticeable power gain..
STi05' is offline   Reply With Quote
Old 05-28-2008, 03:40 PM   #79
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Don't get your hopes up.
Old 05-28-2008, 05:27 PM   #80
Car: '07 STi Limited #482
Stupid question here. Is there any chance of oil shooting out where the cap would be?
I have a perfect way to test this in my car. I do 4th gear pulls all the time at a local straightaway to measure the performance of my roms. I normally do about 3, and then go home and calculate my 2-4k, 4-6k, and 2-6k times. I can easily tell the difference in little things like temperature, timing, fueling, etc. I may try this out and see if there's any difference.
Old 05-28-2008, 05:31 PM   #81
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Well we were saying to put a hose in the hole so that oil doesn't come out. Maybe route it to a can or an A/O separator.
Old 05-28-2008, 05:31 PM   #82
Enginerd
Fav Mod: Tuning
If you drive without the oil cap, you will definitely get oil coming out.
Old 05-28-2008, 05:38 PM   #83
Good to know. Arent the filters directly on top of the spout though?
Old 05-28-2008, 05:43 PM   #84
Enginerd
Fav Mod: Tuning
What filters?
Old 05-28-2008, 05:53 PM   #85
I thought I saw a pic yesterday of a device that's meant to vent the block like this. It was like a big filter on top of the oil inlet pipe or whatever.
Old 05-28-2008, 05:57 PM   #86
That is a domestic thing. Nobody here thinks that is a good idea.
Old 05-28-2008, 08:49 PM   #87
One of the things that should be pointed out here is that the PCV system is designed to slam close a valve if there is a backfire (very unlikely) through the intake that could send flames into the block igniting the crank case vapors thus possibly exploding. (Once again, very unlikey but can happen) So the idea of running a line to the intake without such a device could cause some pretty bad things to happen.
Old 05-28-2008, 08:55 PM   #88
Domestic = USA.... USA is here..
Old 05-29-2008, 09:50 AM   #89
That is a domestic CAR thing. Dodge, Ford, etc. Dammit, it was a JOKE and it backfired...
Old 05-29-2008, 03:31 PM   #90
Enginerd
Fav Mod: Tuning
Lots of people delete the PCV valve and have no problem running 500+ whp.
