| | #46 | |
| IWSTI Club Level 1 Car: The Spaze Mobile Fav Mod: Tuning Location: South O.C., Ca Posts: 13,155
IWSTI Addict since: Jan 2006 Trader Rating: (5) | Quote:
| | #47 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,329
IWSTI Addict since: Oct 2005 Trader Rating: (7) | not doing it on my car, but hey, if you want to run without a cap, go for it. you might also want to check out the turbonator. |
| | #48 |
| Platinum Member | I hear running without a radiator cap helps reduce coolant temps by 20 degrees. Confirm/deny? |
| | #51 |
| i eat cones
Car: 08 MKV GTI Fav Mod: intake Location: ma & ri Posts: 6,848
IWSTI Addict since: Oct 2006 Trader Rating: (21) | so if you have catch cans....... |
| | #52 | |
| Silver Member Car: 06 STI / STG 4 Fav Mod: DOM 3.0R + METH!!!! Location: Vernon, NJ Posts: 1,194
IWSTI Addict since: Jan 2008 Trader Rating: (4) | Quote:
^^^ Yeah that is what I was gonna say like I run the Crawford air / Oil sep is there a diff?? | |
| | #53 | |
| Spec C Club
Car: 06' CGM STI Fav Mod: Rustoleum Flat Black Location: Tracy, NorCal Posts: 1,806
IWSTI Addict since: Oct 2006 Trader Rating: (6) | Quote:
I am waiting on results from flatthump. He knows his shi*. Datalogs and a few "dyno" runs should satisfy even the biggest critic. Or create 20 more pages of debate...LOL KiTsu..get that mill going man! Now, whos got a JDM vented oil cap? | |
| | #54 |
| Spec C Club Car: The Vroom-mobile Fav Mod: JDM Gears Location: San Jose, California Posts: 2,323
IWSTI Addict since: Jun 2005 Trader Rating: (1) | does anyonow the thread of the radiator cap? I'll make one monday if i can get this dimension by then |
| | #55 |
| S204 Racer | |
| | #56 | |
| Junior STI Driver Car: OBP 05 STi Fav Mod: Oh $hti Handle Location: Tulsa OK Posts: 71
IWSTI Addict since: Aug 2007 Trader Rating: (0) | Quote:
![]() Now what I don't understand is how "we" can get a vacuum in to the crankcase to releave the positive pressure sence the cars we drive will build boost. I don't see any other vacuum sorce other than the intake unless we install some other sorce. That is all I was trying to say. "Thank you STI-LOS for the image." | |
| | #57 |
IWSTI Addict since: Jan 2008 Trader Rating: (4) | Quote: I was like man this guy's engine bay is identical to mine.... |
| | #58 |
| Professional STI Driver Car: 06 STi CGM Fav Mod: what you cant see :-D Posts: 420
IWSTI Addict since: Jul 2006 Trader Rating: (3) | that ls1 is most likely a turbo, with the stock pcv system in place a turbo ls1 will simply shoot the dipstick out underhood and blow oil everywhere, hence the air filter. subarus are a pcv system made for turbo cars. |
| | #59 |
IWSTI Addict since: Jan 2006 Trader Rating: (5) | Quote: Tapping into the oil cap just relieves even more pressure in the crank case. Like I said before, Nobody is going to create a vacuum in a crankcase, not unless you're running a super intense vacuum pump. Again, The vacuum source is just to widen the pressure gradient which will allow more flow out of the crankcase. |
| | #60 | |
The OP really just gave me a good idea is all. I'm not looking to prove this will make more power. Anytime you take some oil vapor out of the intake charge you raise the octane of the gas and keep the inside of the intercooler dry. It may add a smidgen of power but what I'm interested in is the consistency of the intake charge (Yes, running a catchcan/Ao separater in between the PCV and valve cover lines is super adequate set-up. I just want to add the last brick is all) This ad is not endorsed by this member. Please register or login to hide this ad. | |
