Old 05-15-2008, 12:15 PM   #16
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Default Re: No Oil cap more horsepower
Originally Posted by flatthump View Post
^NO. Even though you can't feel it, there are vaccuum pulses that come out of the crank case too. If you just have a hole on there you'll get a lot of dust and **** in your crank case...bad idea.
My suggestion is to tap the oil cap with a barbed fitting and run it (in conjuction with your other breather lines) to a catch can.
It's not similar at all to a lightened flywheel. It will just relieve more positive pressure in the case.
I had the catch can idea in my post but I deleted it, I would never just leave an open hole there. So should it be run to a catch can type deal (is oil going to come out) or should a filter be put on top (to catch contaminents and allow the air to exit)?
Old 05-15-2008, 12:19 PM   #17
Car: 07 UGM STI
Fav Mod: Police Scanner
is this thread serious?
csschupp is offline   Reply With Quote
Old 05-15-2008, 12:20 PM   #18
jph
Originally Posted by Szumita View Post
wow... interesting.
that's what i was about to say
J.
Old 05-15-2008, 12:21 PM   #19
Originally Posted by polyol View Post
Ditto...would love to see a dyno graph...
It isn't able to be measured in hp (from what I've gathered). It is kinda like doing lightweight rotational parts (d-train, flywheel, pulleys, etc.), it provides that extra "oomph" just from less stress.
Old 05-15-2008, 12:25 PM   #20
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Filters the worst way you can do it imo. I used to run a filter on my VW bug, but it end's up getting saturated and can't breathe anymore.
The best way is to run it to a catch can that has a vaccuum source. This way you're not only relieving some more crankcase pressure, you're actually sucking some of it out.
Old 05-15-2008, 12:27 PM   #21
Iron Member
Car: 2007 CGM STI
Fav Mod: Extra thug sauce
Send a message via AIM to gametime36
Interesting thread... subscribed.
gametime36 is offline   Reply With Quote
Old 05-15-2008, 12:27 PM   #22
Could you add another tap to an A/O seperator and loop this in? Would that even be beneficial if possible (relieve enough pressure)? As you can tell Steve, this is not my element...
Old 05-15-2008, 12:30 PM   #23
Enginerd
Fav Mod: Tuning
Yeah or you could just T that line into another line that was already running to the A/O seperator.
I like catch cans better though.
How the hell do you spell seperator?
Old 05-15-2008, 12:33 PM   #24
I think you spelled it right. It looked goofy to me too when I typed it.
So, is this mod even worth the time?
Old 05-15-2008, 12:34 PM   #25
Enginerd
Fav Mod: Tuning
How much is your time worth?
Old 05-15-2008, 12:40 PM   #26
Car: 06' CGM STI
Fav Mod: Rustoleum Flat Black
$3 for a plastic T
$10 for a length of hose
My time = $13
I may try this if they have a JDM oil cap with a hole in it.
grambo is offline   Reply With Quote
Old 05-15-2008, 01:05 PM   #27
Fav Mod: AEM Short Ram intake
Send a message via AIM to BMGofUSMC
Interesting to say the least...
BMGofUSMC is offline   Reply With Quote
Old 05-15-2008, 01:25 PM   #28
Car: 07 WRB WRX
Fav Mod: rally school
Send a message via AIM to shockey` Send a message via MSN to shockey`
when you rev the engine with the oil cap off under no load, no pulses of air come out, however when it goes back to idling off boost it does.
why?
shockey` is offline   Reply With Quote
Old 05-15-2008, 01:27 PM   #29
Enginerd
Fav Mod: Tuning
why?
Cause you're increasing the vacuum in the inlet pipe faster than you are increasing crankcase pressure.
Trust me, when you're full boosting, you have a a lot more positive crank case pressure.
Old 05-15-2008, 01:54 PM   #30
Car: STi
lolz!
flamin is offline   Reply With Quote
