Old 05-15-2008, 10:19 AM   #1
Fav Mod: tbe
Send a message via AIM to SoflaSTI
Default perrin headers installed
Hey all just got my perrin headers installed by my tech. They are great but i have one issue maybe someone can adress. When i give my car a slight rev i hear a raddle type noise. It only happends when i get on it somewhat or just rev it up. Maybe its the heat shield raddling on the uppipe? or maybe my clamps on the headers? any ideas? i highly doubt its cracked trust me its the first thing i thought of.
Thanks all!!
SoflaSTI is offline   Reply With Quote
Old 05-15-2008, 10:28 AM   #2
Fav Mod: Do Luck CF
Default Re: perrin headers installed
Is it a rattle or more of an exhaust leak type sound. If it is the latter... welcome to the suckage that is known as Perrin EL header slip joints. I spent almost $150 in random stuff and different ideas to get my Perrin header to seal up worth a crap. For your sake - I hope its something else.
Old 05-15-2008, 01:40 PM   #3
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
Check for leaks adn clearance issues. If the headers are leaking you must have a black carbon mark in the flanges.
BBBsti LTD is offline   Reply With Quote
Old 05-15-2008, 01:45 PM   #4
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Just check all of your heat shields, that sounds like what it is. Good luck.
Old 05-15-2008, 02:00 PM   #5
jph
which heat shields? there shouldn't be any left after removing the OEM header.
but i have to agree, that your installer must have not tightened something, or knocked something else loose.
impossible to diagnose over a forum.
have someone sit in your car, and rev it a few times while you stick your head in the engine bay watch out for moving fans/belts though, and try not to get burnt
J.
Old 05-15-2008, 02:19 PM   #6
Fav Mod: tbe
well
1. i do under the table work with my 8 year subaru tech. i trust him espically knowing hes built many rotated mount kits etc.
2. i looked under the car no signs of cracks i saw a clamp rubbing the motor mount so i moved that.
3. Its werid because it only happends when i take off from a stop. ill hear a raddle then its gone. Like when you take off your engine shakes a bit so thats what im thinking. I just dont see how the header could of cracked already. Yea, ive read the fourms etc. i no they are prone to crack overtime but damm 2nd day? doubt full.
Old 05-15-2008, 02:31 PM   #7
jph
you don't happen to have an APS CAI do you?
J.
Old 05-15-2008, 02:42 PM   #8
Fav Mod: tbe
no perrin
Old 05-15-2008, 02:44 PM   #9
Fav Mod: tbe
i dont know if i mentioned this but i can hear it most towards my passenger side door. Like where the uppipe is. arghhhh. If it was a leak wouldnt i hear it all the time? espically on wot? I havent had a leak so i really dont know what im listening for. For right now all i hear is a kinda baning sound. To metals hitting each other or like a loose screw jiggling around. Then again i dont know what a real exhaust leak sounds like. Thought i was more like a wistle
Old 05-15-2008, 02:49 PM   #10
I know that the header heat shields are gone J. I was talking about the uppipe one and if he has one over the dp, to check that too. My uppipe shield was loose and although it never made noise when driving, I could move it around and make it make noise. Just recheck everything that you touched during the install.
BTW, how do you like the EL sound? I plan on buying this header in the future.
Old 05-15-2008, 03:03 PM   #11
jph
it rocks!
i will be adding a perrin header to my '08 as well.
http://traumatized.org/wrx_sti/img/p...EQ_headers.wmv
J.
Old 05-15-2008, 03:06 PM   #12
Car: black wingless 06sti
Fav Mod: accessport!!!
i had the same prob when i installed my headers...and it was vibrating on the metal where the pipes met the collector .....i just bentit down around the area where it was hitting and never heard it again =)
evil06sti is offline   Reply With Quote
Old 05-15-2008, 03:08 PM   #13
I've also read about headers hitting the subframe, check that!
Old 05-15-2008, 03:09 PM   #14
Originally Posted by jph View Post
it rocks!
J.
Nice. I want to buy the header over the tires but the whole safety thing, ya know.
Old 05-15-2008, 03:13 PM   #15
Car: The Vroom-mobile
Fav Mod: JDM Gears
better yet, you buy headers and i'll buy tires!
didnt we have a leak when we did yours j?
