Old 05-10-2008, 07:49 AM   #1
Car: WRB 2002 wrx
Default 20G install questionw/EWG
In the process of installing my 20g on my WRX.
Some questions or problems I am coming up with
The WG arm on the stock one is controlled with that vaccuum thing (broze cylnder type thing) but on my 20g it doesn't have one . Do I tighten the WG arm down tight shut, or just snug, or leave it loose?
If anyone can post a picture of their EWG setup would really help so I can see how to route the vaccuum hoses in and out of the Tial 44 EWG.
thanks
ultramagnus is offline   Reply With Quote
Old 05-10-2008, 08:00 AM   #2
Fav Mod: Tial 44mm EWG
Default Re: 20G install questionw/EWG
im pretty sure you either have to have a bracket made for your 20g if its internally gated or you have to weld it shut on the inside
Old 05-10-2008, 08:07 AM   #3
Car: WRB 2002 wrx
i have to weld the inside flap shut?
or can i just tighten the arm down all the way? it doesn't look like its doing anything anyways, doesn't the EWG control everything now?
Old 05-10-2008, 08:24 AM   #4
im pretty sure if u dont get a bracket or weld it shut it will still open and cause it to leak. YouTube - IWG install
Old 05-12-2008, 04:47 AM   #5
Reasonable
Fav Mod: correct grammar
Again, posting in the correct forum helps.
Old 05-12-2008, 06:05 AM   #6
in order to run an EWG you'll need to either weld the internal flap shut or create a bracket. when i find the pics of my custom bracket i'll post them asap.
Spunky424 is offline   Reply With Quote
