Old 05-03-2008, 09:36 PM   #1
Car: 04 WRB STI
Fav Mod: Bailey Tuned GT52 for 435/454
Default GT52 In The House!
Just finished up the install of my new GT52. I am so excited to see what this unit is going to do on my car after all the talk about it. I am coming from a 20G that made 370/404 on a dyno jet and trapped around 113-114 on pump gas. Tim Bailey will be tuning my car next Sat. I hope. My goal is to run 11's on pump. I may be doing a C16 tune too, but I don't know. I am still on a stock block that seems to be very healthy and I want to keep it that way.
I do have a question for those of you with an Element GT52. Have you had any problems with the inlet tube collapsing? I am running a Perrin inlet tube. Also what kind of times and trap speeds are you seeing?
highpsi is offline   Reply With Quote
Old 05-03-2008, 11:00 PM   #2
Car: 06 STi
Default Re: GT52 In The House!
Make sure you post some dyno pulls and time slips. You running fmic and/or meth?
Iirc- i've only read of the perrin inlet collapsing on high psi, like race gas tunes pushing over 25lbs of boost. Those that had it happen will chime in eventually.
Old 05-04-2008, 05:33 AM   #3
Car: 04 WRB STI
Yes I am running a FMIC. I will probably be at around 21 on pump and 25 or so on C16. I don't want to push the motor too hard since it's stock, lol!
I will post the dyno graphs and 1/4 mile times for sure.
Old 05-05-2008, 08:59 PM   #4
HowTo Contributor
Fav Mod: Cobb Stg 2 - Wrapped DP
waiting for results
Old 05-05-2008, 09:06 PM   #5
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
^ same
B4RSTiwsnc is offline   Reply With Quote
Old 05-06-2008, 04:13 AM   #6
Car: 04 WRB STI
I should know Sat!
Old 05-11-2008, 07:31 PM   #7
HowTo Contributor
Soooooooooooooooooooooo, results are?
Old 05-11-2008, 07:35 PM   #8
Tim Bailey got sick, postponed till this coming weekend at E-motor in Indianapolis. Chad will put down some GREAT numbers on that dyno.
MattPersman is offline   Reply With Quote
Old 05-11-2008, 07:36 PM   #9
HowTo Contributor
damnit
Old 05-12-2008, 04:10 PM   #10
Car: OBP 06 sti
Fav Mod: agile protune
I had issues with the perrin inlet collapsing @ 21.5 psi with the green. It happened after the 5th or 6th pull and the motor was obviously hot. My tuner suggested the APS hard inlet, but I did not want to go through the intake removal. I ended up going with the AVO inlet from rennick motorsport. Nice JDM peice and collapsing issues solved. The perrin unit is like a jelly donut when hot.
needmore is offline   Reply With Quote
Old 05-12-2008, 04:13 PM   #11
HowTo Contributor
i have heard good things about Gimmick's inlet tube as well, some negatives like 1 or 2 people getting collapsing issues, but alot more positive than negative.... APS puts out a fine product but i heard that the inlet is a PITA
Old 05-21-2008, 09:20 AM   #12
what injectors are you running with the GT52. wonderin if my nismo 750s are enough for this turbo.
thanks
Spunky424 is offline   Reply With Quote
Old 05-21-2008, 02:08 PM   #13
HowTo Contributor
still waiting for updates
Old 05-21-2008, 02:17 PM   #14
Car: 07 SWP STI
Fav Mod: Blouch Dom 3R
Send a message via AIM to Turbo_Joe
thanks
I'm getting this turbo as well, and will be putting in dw750s with meth. Not sure if 750s without meth will be up to the task. Someone with experience will correct me soon, lol.
Turbo_Joe is offline   Reply With Quote
Old 05-21-2008, 03:17 PM   #15
HowTo Contributor
Im hoping for this turbo and will be using 850 deatschwerks w/out meth
