| | #16 | |
| Spec C Club
Car: Blue 05 STI Fav Mod: 4th gear wheelspin Location: Upstate NY Posts: 1,931
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Quote:
If I could do it over again I would have replaced my stock short block with another stock short block. Hell I could have bought a couple used longblocks for the amount of money I have under the hood of my STI. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #17 | |
| S204 Racer | Quote:
Either way, the key is to set the P-SW clearances to a reasonable limit. The .003-.0045" that most aftermarket builders are using is totally useless for the average guy around here. IOW, all the extra clearance does is make it an oil burner, and it robs power unless the block is really, really hot - as in extended "track use" hot. And how many of these engines will ever see that type of duty? Damn few. Now, for the very non-average joe who is building a motor for dedicated track use? I'd suggest either a motor from Ron, or Cosworth, period. With a proper tune, those motors have proven to be bullet-proof. Will they outlast a stock motor if used in a street application? I dunno...but that isn't the point. | |
| | #20 |
| The Next Petter Solberg Car: 05 STI Fav Mod: GT30R Location: OC, California Posts: 858
IWSTI Addict since: Mar 2006 Trader Rating: (0) | I've had great luck with the stock motor and so have many others at even higher hp levels than me.. All u people out there considering a built block, look at what these people are saying that have gone thru building an expensive motor, keep ur stocker till she let's go! N hell mine has lasted so long when it finally does go im just gonna replace it, maybe with forged pistons but other than that that's it.. |
| | #23 | |
| STI Driver Car: 04 Subaru WRX STi Fav Mod: downshifting to 5th Location: South-Central VA Posts: 246
IWSTI Addict since: Aug 2006 Trader Rating: (2) | Quote:
it all depends on the builder and the parts you select. everyone's got their own opnions on what really works and everyone swears by those opinions, still doesn't mean they're true. i've seen a lot of positive things come out of shops like ARfab and crawford for example. serious power with complete reliability is a fallacy however, from the time the first modification goes on the car, reliability decreases. it's just something we all deal with. tuning is also a pretty essential piece to this process as well. so, in short, there are lot of factors to account for in the building of a motor. | |
| | #24 |
| Professional STI Racer Car: 2006 Subaru WRX STI Fav Mod: Maddad DP and P&L Catback, stage 2!!! Location: Omaha, Nebraska Posts: 628
IWSTI Addict since: Oct 2006 Trader Rating: (9) | u cant say that because you have seen a couple subaru engine blown, that it is some how inferior. ive seen hondas blow on the dynos, ive seen a old shelby cobra blow on dyno. i mean if its gonna happen, its gonna happen. you are well aware that with building aftermarket engines and pushign things to their limits.. things might break. |
| | #25 |
| Professional STI Racer Car: 04 WRB STI Fav Mod: vf36 Location: 315 awhp 371 ft/lbs Posts: 810
IWSTI Addict since: Jul 2004 Trader Rating: (4) | I had just spun a rod bearing this past Thursday. Option 1: Buy a brand new shortblock from the dealer, drop in forged Weisco pistons and maybe Manley Turbo Tuff rods. Upgrade main and rod bearings to Cosworth's tri-metal bearings. *Upgrade to Cosworth oil pump *ARP head studs *Cosworth or Cometic head gaskets Option 2: Have Darton sleeve and assemble a used shortblock with the same components as above Option 3: Find used short block and have Benson Auto Machine in Santa Ana, CA install ductile iron sleeves, and assemble with same components as above Option 4: Buy an assembled closed deck shortblock with h-beam rods and JE forged pistons from either Harmon Motive or Outfront motorsports (builds high power sandrail motors here in Socal) Option 5: Buy Cosworth 2.5 lit shortblock What kind of damage can a spun bearing do to the block casing, crank, and rods? Is it bad to install ductile iron sleeves on an ej257? Anyone use a closed deck block? |
| | #26 |
| The Next Petter Solberg Car: 2005 STI Fav Mod: Methanol Location: Boston area Posts: 932
IWSTI Addict since: Feb 2005 Trader Rating: (5) | at 425 WHP my stock shortblock let go. I thought I would be safe, but it lasted about 2 weeks. I am going with a built shortblock, I dont want to worry about it. This ad is not endorsed by this member. Please register or login to hide this ad. |
