Old 04-05-2008, 01:58 PM   #16
Car: 06 sti
Fav Mod: invidia turbo back exhaust G200
Default Re: EWG spring pressure
Originally Posted by JDM-STI View Post
No. You usually cant run more than double your spring pressure. And if you can, you shouldn't IMHO.
ok, i respect your opinion but can you explain why? if needed i will try to get another spring in there before then if i can find them in stock somewhere and overnight it to me.
gohrsepwr is offline   Reply With Quote
Old 04-05-2008, 04:53 PM   #17
Car: 2005 & 2008 STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
You will have to max out your WG duty cycle in order to get the spring to hold to double its rating. And even then, you will likely get uncontrollable and inconsistant boost. It's just not a very good way to go at all. Extremepsi.com usually has WG springs in stock, and they ship very fast.
JDM-STI is offline   Reply With Quote
Old 04-05-2008, 09:11 PM   #18
Car: 06 sti
thanks for the info, new spring orderd!
Old 04-05-2008, 09:57 PM   #19
Fav Mod: GST Protune, less boost more power
Send a message via AIM to MorePSiTehBett4
running the 1 bar spring as well in my tial 38, my ewg came with a 1 bar spring and the other lower spring(i forgot the number)
MorePSiTehBett4 is offline   Reply With Quote
