Old 05-20-2008, 02:07 PM   #76
Car: 07 sti
Fav Mod: whats a mod?
IWSTI Addict since: Feb 2007
Default Re: Turbo Blanket Info and Writeup inside
Originally Posted by STI-LOS View Post
Why not?
the turbine housing gets hotter than that. it looked decent at first, but now it looks like its going to be underengineered. for the little $$$ difference, i would just buy a proven one like the boostlogic or the one i posted.
Old 05-20-2008, 02:12 PM   #77
IWSTI Addict since: Aug 2006
Trader Rating: (14)
do they have a version that fits IWG?
Old 05-20-2008, 02:13 PM   #78
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
IWSTI Addict since: Jan 2008
D you think the Boost Logic is rated for more.. You have to remember that his rating might be the true *rating* and just cause our housing may see temps a bit higher doesnt mean anything. Just like my HPC extreme coating they advertise 2000 degree heat rating that doesnt mean its the true actual rating. So you know there is no diff in the boostlogic or this one.. If I was to turn the boostlogic one upside down and run it with the outside part on the housing the same thing would happen, you know that right..
Old 05-20-2008, 02:24 PM   #79
Car: 07 sti
the boostlogic one has been around a long time and i have never heard about one burning up so i could care less what its rated at, im more concerened with its actual performance. its not like this ebay one (so far with a bad failure rate) is cheap enough to chance it, they are pretty much the same price! i have nothing against the company that makes then, and im not a boostlogic fanboi, im just calling it like i see it.
Old 05-20-2008, 02:25 PM   #80
Car: 07 sti
for an iwg, guys just trim it.
Old 05-20-2008, 06:51 PM   #81
Car: 06 WRX SGM
IWSTI Addict since: Jun 2006
You really don't want to buy an underengineered piece of fabric that sits right on top of one of the hottest points in your car... I'm really interested in hearing more about this piece before I buy it as well.
bdon22 is offline   Reply With Quote
Old 05-22-2008, 06:21 AM   #82
IWSTI Addict since: Apr 2008
thx for the post..... it was helpful
awoo23 is offline   Reply With Quote
Old 05-22-2008, 07:02 AM   #83
Evil Monkay
Car: 06 Subaru WRX STi -
Fav Mod: Hydra
IWSTI Addict since: Oct 2006
Subie Love
Silver SEMA 2007 Sponsor
Send a message via AIM to bbong Send a message via MSN to bbong
Anybody familiar with Turbo By Garrett Blankets, or where to get them? Looks like these are a real deal ones
bbong is offline   Reply With Quote
Old 05-22-2008, 05:00 PM   #84
Fav Mod: Driver weight reduction
IWSTI Addict since: Oct 2005
People, people.....
This turbo blanket comes from New Zealand. They use a metric measurement system there (offically as of 12/14/76). All degrees aren't created equal and the number means nothing without the unit behind it. The temperature ratings quoted by the seller are almost certainly in C, not F.
1100 C = 2010 F
300 C = 572 F
Those temperature ratings are very good for this type of a product. Most people's EGT's at the heads never go over 1650 F. My blanket is still in great shape and is not brittle in any shape or form.
Good2Go is offline   Reply With Quote
Old 05-22-2008, 07:24 PM   #85
Car: 07 sti
i wouldnt doubt the boostlogic and garett are the same. they both look great. do a google search, im sure a ton of vendors will pop up.
Old 06-09-2008, 02:36 AM   #86
IWSTI Addict since: Aug 2003
i have a question about the install to this..
I have a vf34-p20 housing turbo, did u install the blanket when the turbo was mounted or did u take it off?
Also - which side did u tuck under the wastegate , the wide or thinner side??
waxdass is offline   Reply With Quote
Old 06-09-2008, 08:13 PM   #87
bump!? anyone
Old 06-10-2008, 06:46 AM   #88
Car: 07 Subaru STi
Fav Mod: Coilovers/Tune
IWSTI Addict since: Nov 2006
Send a message via AIM to IGoFast1589
Anyone have any info on engine temperatures with and without a blanket yet?
IGoFast1589 is offline   Reply With Quote
Old 06-10-2008, 06:48 AM   #89
Car: 07 Subaru STi
Originally Posted by jtrafidlo View Post
I installed the ebay one from the first post and it is a beast. The Static X one I had is a joke compared to this one, luckily I got that one free. This one is thick, really thick and well made. It is kind of a PITA to get on while the turbo is on the car, but not too bad. It only included one stainless steel clamp, and the blanket does not fully cover the entire turbo. I am on the stock turbo setup. i would recommend it though.
Where did you order it from? I am using the stock turbo as well, is it worth it? How did you install it while the turbo was still no the car?
Old 06-12-2008, 09:22 AM   #90
Car: 07 Subaru STi
Bump for this thread! I'm considering purchasing a blanket and would like any info that you guys may have.
