Old 03-15-2008, 11:31 AM   #1
Default Mishimoto Radiator installed
About a week ago I get to autozone to buy some stuff, when I come out my car was steaming and pissing out coolant. Two months ago I had purchased some silicone hoses and 160 degree thermostat. I did the install and everything seemed good. After about a week I started have seeping issues from the hoses, so I cranked them down some more. Did not help at all, so I tightened them till they could not go know more. Still with them that tight they still would seep. After inspecting, it seemed like the stock clamps just could not pinch the hard silicone hoses enough. Which now leads me back to autozone.
I popped the hood and my top radiator hose blew right off. When I looked at the radiator inlet, the lipped cracked right off and the hoses just slid off. So I add to unfortunately purchase a Mishimoto Aluminium Radiator. I have seen pics in magazine and it looked great. When I received it in,WOW. It looks great and I made the switch. It did not come with radiator fans bolts like it said but a trip to autozone fixed that. It does come with a new radiator cap(1.1bar). I just had to shortened the top hose alittle on the block side. I would have posted pics but the camera crapped out.
SubySteve is offline   Reply With Quote
Old 04-11-2008, 03:28 PM   #2
Car: 04 WRB STi
Send a message via Yahoo to allwheelsdriven
Default Re: Mishimoto Radiator installed
so are you happy with it?
allwheelsdriven is offline   Reply With Quote
Old 04-11-2008, 03:35 PM   #3
I have had it on for about 4week now and no problems. For the money nothing comes close. Its about half the price of a koyo and double the size of the stock radiator.
Old 04-11-2008, 03:36 PM   #4
Car: 04 WRB STi
my stocker is starting to get that greenish crusty stuff around the edges so i can see replacing it soon
Old 04-11-2008, 03:43 PM   #5
I definitley recommend the radiator, talk to Josh at importimageonline. Great with processing and shipping the order fast.
Old 05-19-2008, 11:03 AM   #6
Evil Monkay
Car: 06 Subaru WRX STi -
Fav Mod: Hydra
Subie Love
Silver SEMA 2007 Sponsor
Send a message via AIM to bbong Send a message via MSN to bbong
I just got one from Josh, we'll see how it holds up to the summer heats.
bbong is offline   Reply With Quote
Old 05-21-2008, 02:44 PM   #7
Car: 05 STi, Black
Fav Mod: Graduating from college, and falling in love with turbines...big and small.
hey - same here...after getting protuned last week and a few spirited excursions over the weekend, i've noticed the water temps have increased in tendency to climb into the hot side. got the radiator and hoses combo from Josh as well.
Did your seep issues go away after replacing the rad? do you think the seep was actually traceable to the stock rad?
blackie1969 is offline   Reply With Quote
Old 05-21-2008, 03:05 PM   #8
Car: 06 Aspen/gold STi
Fav Mod: Whatever I buy next
lets see some pics when you get the camera fixed!
C.J. is offline   Reply With Quote
Old 05-21-2008, 05:15 PM   #9
After I went back to the stock hoses, I have had no seeping issues. As far as temp spikes, I have not had any. Its sounds like you have air in your system. I never go more than a tag over the first line and I live in florida. What coolant are you using?
Old 05-21-2008, 06:00 PM   #10
Trader Rating: (14)
how much thicker is the core versus stock? Anybody happen to measure them? thanks
Old 05-21-2008, 06:43 PM   #11
Evil Monkay
Fav Mod: Hydra
Subie Love
Steve, can you clarify? You've had seeping with the GMS Silicone hoses that came with the Mishimoto Radiator Combo buy, or they were some other aftermarket hoses?
Old 05-22-2008, 08:57 AM   #12
I first started out with the stock radiator an gms hoses. Once the hoses were on I kept getting seeping on the upper hose where it mounts to the radiator and block. No matter how tight the clamps got, it did not make a difference. Took them off and sanded the inlets and still it kept seeping. I guess I tightened the radiator side to much and cracked the inlet on the stock radiator. I bought the mishimoto radiator and put the stock hoses back on and its been all good since.
Old 05-22-2008, 09:01 AM   #13
Evil Monkay
Fav Mod: Hydra
Subie Love
Great, thanks for your prompt response to my question, I'll give it a try with GMS hoses and Mishimoto Radiator. You should have tried getting those hoses replaced, who knows maybe they're defected.
Old 05-22-2008, 11:36 AM   #14
I will never use silicone hoses again.
Old 05-22-2008, 12:51 PM   #15
Car: 05 STi, Black
i have the stock fluid in the car, changed only once at around 50k. sounds that that may indeed be the case with the spiking. my intent is to add heat rejection capability to the car for track events during the summer. last summer i boiled the fluid during a late June event. fall event was ok.
have another event in a couple weeks and would like this to not happen again.
Thanks for the input...will def keep that in mind.
Ruben
