Old 03-08-2008, 07:58 PM   #1
Car: 07 Subaru STI
IWSTI Addict since: Apr 2007
Default Gruppe-s
Im planning on installing a turbo kit on my 07 STI soon and have a question about Gruppe-s built blocks. Ive been told that my stock motor should be good to go with a tune around 320whp but I should start saving for a built block to be safe or if I want more power. Gruppe-s has one for approx 2800 bucks which sounds like a good deal (block, pistons, rings, crank and rods). Not sure on the quality or if anyone has one in their car....any thoughts?
subiecop is offline   Reply With Quote
Old 03-08-2008, 08:01 PM   #2
Car: 04 sti
Fav Mod: enginuity tuned
IWSTI Addict since: Aug 2007
Default Re: Gruppe-s
people have gone as high as 550whp on the stock block & internals. whether or not they last is yet to be seen. i wouldn't worry about building up your block until 400whp+.
i'd rather get a built block from raw performance or source my own parts.
Old 03-08-2008, 08:10 PM   #3
Car: '08 BMW 135i
Fav Mod: Jack's smirking revenge.
IWSTI Addict since: Nov 2006
Send a message via ICQ to jtsherri Send a message via AIM to jtsherri Send a message via MSN to jtsherri Send a message via Yahoo to jtsherri
Not to thread jack too early on, but...
Some/most will tell you not to worry about the block this early on; however it doesn't hurt to be prepared AND I'll put $$ on you making more than 320 whp on 93... Not a WHOLE lot more, but wouldn't be surprised if you were making 330-335.
ALSO, you need to make sure to specify that the dyno you're rolling on in an unforgiving, heartless ***** (but probably one of the most accurate reading ones around) AND the info on your turbo setup...
jtsherri is offline   Reply With Quote
Old 03-08-2008, 08:11 PM   #4
Car: 07 Subaru STI
Yeah, Ive heard that also. Im just being overly cautious I guess. Im putting in a Green and was looking for around 320ishWHP. I think that with those numbers it would be a blast as a DD and I would have low risk of popping the motor.
Would it be a bad idea to keep the stock block and just get pistons, rods, rings etc?
Old 03-08-2008, 08:13 PM   #5
Car: 07 Subaru STI
You can thread jack all you want bro...I was trying to keep from bothering you with all my questions......
Old 03-08-2008, 08:14 PM   #6
Car: 06 WRX STi
Fav Mod: my furry little four legged Australian Sheppard co-pilot
IWSTI Addict since: Oct 2006
Send a message via AIM to atsi sti
let jtsherri tell you about his story...
atsi sti is offline   Reply With Quote
Old 03-08-2008, 08:15 PM   #7
Car: 04 sti
you'll easily hit 320whp with just a turboback and tune. even with a green you won't have much worry at all as long as you get a really good tune. most people pop motors cause of bad tunes
keeping the stock block isn't a bad idea at all. saves money and you can source the parts as you wish.
Old 03-08-2008, 08:16 PM   #8
Car: 07 Subaru STI
I guess I should clarify my question...
I am unsure if I actually should, at some point, get a new block or can I just get the internals. If I should get the whole badboy setup then is Gruppe-s a good company? I know Crawford makes good toys but its a tad above my payscale...any thoughts?
Old 03-08-2008, 08:18 PM   #9
Car: 07 Subaru STI
i was tryin not to bother jtsherri....
I've got a $hitload of questions and I feel bad always bending his ear...
Old 03-08-2008, 08:18 PM   #10
Car: 04 sti
gruppe-s is a good company but explore all your avenues before making a decision. raw performance is a good place to start.
Old 03-08-2008, 08:20 PM   #11
Car: 07 Subaru STI
My current power set up is as follows:
Intake, catless DP, exhaust and a street tune. What I plan on installing (thanks to a friend of mine) is a Green, 850injectors, fuel pump, new DP with EWG and some dyno time.
Old 03-08-2008, 08:25 PM   #12
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
IWSTI Addict since: Jan 2008
I wouldnt worry about upgrading your block.. Like was said there is guys pushing alot of power on the stock block... I mean all depends at your goal for the car but if its under 400WHP your good the stock block is capable... Dont fix it if it aint broke is what I say..
Old 03-08-2008, 08:29 PM   #13
Car: '08 BMW 135i
They're no problem, man... I'm always game to help in any way that I can.
In my opinion, for $2800, you can't go wrong... From what I've heard, the Gruppe-S blocks are pretty nice; however, don't forget about all of the other goodies you'd need to go along with it (gasket set, oil pump, timing belt, tensioner, etc.) - that stuff can add up quick too.
I'm going to stand by my original advice and vote that if you're REALLY worried about it, start throwing some change in a jar every month, put some masking tape on the jar and pull out a Sharpie to mark it as your "Motor Fund" - I really and truly feel that you have nothing to worry about; however, it NEVER hurts to be prepared!
I wish I could give more feedback on the Gruppe-S motors, but have zero knowledge on them, outside of the positive feedback that Jan gave me on the one he installed not too long back. Hopefully some others can chime in with some good info.
Old 03-08-2008, 08:32 PM   #14
Car: 04 sti
the block will be fine with the green and supporting mods. i'd invest in the fuel pump asap with the issues some 07s have encountered.
run the car with your new setup while saving up for either a new block or just new internals. it might never come to that but at least you'll have the money. if you don't need a new block, you'll have a stash of money for you to spend on whatever!
Old 03-08-2008, 08:33 PM   #15
Car: 07 Subaru STI
will do bro. yeah, ive been setting money aside just in case.
be prepared for some more questions my friend...
