| Junior STI Driver | i just finished installing my boost gauge (greddy 52mm v.2) everything was working fine minor boost leak but fixed when i was taking it on a test spin i would get on the gas 2nd gear 14.8 pounds but as the rpms rose the peak would drop out down to like 12 in 3rd gear i noticed the same exact thing boost peak then drop.... the major problem is there is a tremendous loss of power i mean bad extremely noticeable 2nd gear feels like 4th i took the t-fitting out and put it back to stock and i can feel the same thing peak boost acceleration around 4.5k then power loss again car feels faster but still way to slow any ideas i dont know what to do car is a '04 sti with 49k on the clock This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| I'm Jim Halpert
Car: 06 WRB STI Fav Mod: EWG Location: Irvine, Ca Posts: 6,793
IWSTI Addict since: Apr 2006 Trader Rating: (9) | i need more details on how you installed it. Which line did you cut etc........ |
| | #4 |
| Junior STI Driver | didnt cut any lines i bought another tube same size as stock about 2 inches long took off the piece on the stock bpv then placed my 2in section on then the Tfitting then my stock line uncut |
| | #6 |
| I'm Jim Halpert
IWSTI Addict since: Apr 2006 Trader Rating: (9) | Do you have a picture? what size t fitting did you use? Did you you use hose clamps? |
| | #7 |
| Junior STI Driver | is the restrictor pill that little gold piece that comes with the t fitting? the t fitting i used came in a assorted box i believe it was 1/4? yes i used hose clamps i also disconnected my battery which prolly reset my ecu? but i have intake and exhaust could this cause my power loss because the car has to relearn the intake exhaust? |
| | #8 |
| I'm Jim Halpert
IWSTI Addict since: Apr 2006 Trader Rating: (9) | tbe? It sounds like you installed it right. Do you hear any boost leak from that area? |
| | #12 |
| Junior STI Driver | wow just fixed the problem it was the ecu going back to stock maps did the reset with the 3rd gear boost hold instant power fix thanks for all the quick answers guys |
| | #13 |
| I'm Jim Halpert
IWSTI Addict since: Apr 2006 Trader Rating: (9) | ya make sure u flash it to the base map not realtime |
| | #14 |
| Junior STI Driver | whats the difference sorry im still a suby nooby lol i just firgured this stuff out right now i have no type of EM just going based of what im reading slowly lol This ad is not endorsed by this member. Please register or login to hide this ad. |
