Old 01-30-2008, 01:48 PM   #1
Car: Black 07 WRX STI
IWSTI Addict since: Dec 2007
Default 07 STI - Inconsistent Boost
Hi,
My stock STI has about 7000 kilometers on it. I received an 07 ECU update about 3000 KM's ago, this fixed some of the jerkiness upon throttle-down, and apparently fixed some power issues around 3000-4000 RPM. However, I still continue to have inconsistent boost. The dealer says the car is fine, but I still notice that sometimes I get good boost, other times with the same throttle position and car speed, it feels like the car has less power. Sometimes it even feels like the boost is coming in "clouds" (uneven). It is a leased vehicle so I want to keep it stock. Any suggestions on this boost issue?
Cheers,
RV
rvares is offline   Reply With Quote
Old 01-30-2008, 02:13 PM   #2
Fav Mod: Gram Light 57F's
IWSTI Addict since: Apr 2007
Send a message via AIM to jordanretro1223
Default Re: 07 STI - Inconsistent Boost
The only way you're going to be able to fix all the problems you have listed is by relashing the ecu. Either with Cobb stg 1 or some open source map. The 07 STI stock tune sucks and these problems are unavoidable even on the factory reflash.
jordanretro1223 is offline   Reply With Quote
Old 01-30-2008, 03:46 PM   #3
Banned
Car: WRB 07 STi
Fav Mod: Cobb AP
IWSTI Addict since: Jan 2008
exactly what he said. AP Stg I
alihamza is offline   Reply With Quote
Old 01-31-2008, 08:16 PM   #4
Thx for the Cobb information. As an update, the dealer had my car for 2 days, took it apart many times trying to find the problem. They managed to get some data showing the inconsistent boost. They said that the catalytic on the downpipe is faulty and have ordered a replacement for next week. They put the car back together temporarily until the part comes in. The car has even less boost now. Have you folks run across catalytic's causing such a problem?
Old 01-31-2008, 08:58 PM   #5
Car: 07 Subaru STi
Fav Mod: Coilovers/Tune
IWSTI Addict since: Nov 2006
Send a message via AIM to IGoFast1589
Cobb Stage 1 will make it better but not cure the problem. The best thing you can do is get your car tuned by a professional.
IGoFast1589 is offline   Reply With Quote
Old 02-07-2008, 08:54 AM   #6
Car: White 07 STI
IWSTI Addict since: Oct 2007
i am running the same issue.
I had to wait to bring my car in to the shop and by the time i did i had no boost at all.
The dealer took apart my car and found that the first cat split into pieces like a pie.
When this happened i assume that pieces of metal went and got stuck in the other cat, and also went back into the turbo and completely messed everything up.
After they replaced my turbo and exhaust is was running fine.
Now i seem to be losing power again and i just took it into the shop and they told me it was fine and that it was hitting boost properly.
let me know if you figure out what is going on with the 07's.
I am waiting to do mods until i can figure this one out first.
I would hate to void the warranty by putting on some mods, and then have something happen again
eaglesfan6699 is offline   Reply With Quote
Old 02-07-2008, 06:39 PM   #7
Hi,
I will advise you as I proceed. So far, the factory downipipe is on backorder...ETA unknown (which now makes me suspect that this is a cronic problem)...at this point I kinda miss my bullet proof Honda V6 (I had my foot mashed through the floorboards for 4 years straight and it never coughed once (what a sweet motor at high revs).
Cheers,
RV
Old 02-08-2008, 11:01 AM   #8
IWSTI Addict since: Oct 2006
The 07's are known to have Jeckly and Hyde Syndrome.... only way to cure it is with a protune, and upgraded fuel pump (stageII). The ecu likes to retard boost any time it sees something it does not like, and then after about 50 miles or so it reverts back to a beast. Then you start mashing the gas, the ecu sees something it does not like, and the vicious cycle continues all over again.
Varanont is offline   Reply With Quote
