| | #31 |
| Hungry Hungry Hoodscoop
Car: 32J GDFDYEH Fav Mod: Fullerton's Qrack on my car Location: Chicagoland Posts: 3,827
IWSTI Addict since: Apr 2006 Trader Rating: (23) | subscribed for future reading enjoyment This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #32 | ||
| Authorized Vendor
Car: STi GT35R Powered Fav Mod: Innovative Tuning Location: Buffalo, NY Posts: 248
IWSTI Addict since: Jan 2006 Trader Rating: (0) | I'm glad you guys enjoyed this. I've written a few quick tech threads over the years on various board so I'll put a few more up if anyone wants to read further. CenCali07STI good work sorting berdugo's confusion out. Quote:
![]() Onto your question, since we're talking about % gains, keeping the percentage equal, the lower the HP you start with, the lower the gain in HP with be from intercooling. For instance a 50% gain on 200 hp (non intercooled) is 100 hp while a 50% gain on 400 hp (non intercooled) is a 200 hp gain. Then you figure in your usage. Here are a few examples: If it's a street car that never gets raced, power probably isn't much of a concern at all so it's hard to argue for changing anything on a stock turbo setup. If you autocross on a stock turbo, the front mount will make power delivery a more consistant and you'll have more overall power, but you may not be able to make use of any extra power on some courses. Some people also complain about lag with a FMIC, but honestly on a 6 speed if you're out of the powerband on a stock turbo, you're in the wrong gear. If you rally, you have to consider the benefit of the consistancy and power vs. the vulnerability of having an intercooler up front. Personally I feel if your IC is going to get smashed, your radiator would have been smashed and you'd be done anyways, but some people feel otherwise. I feel that when you're running restricted you have to maximize the power potential of the limited amount of air you can ingest so good intercooling is vital. If you drag race, slow shifting can negate the advantage of extra power from the front mount on a stock turbo, but those that shift very quickly do see a benefit. To be clear, this is how I feel about the stock turbo only. As the power level goes up, the advantages of a GOOD front mount become overwhelming. | ||
| | #33 |
| STI Driver Car: 03 mbp gga Fav Mod: 12.9 / 105+ Location: lincoln, ri, usa Posts: 237
IWSTI Addict since: Dec 2005 Trader Rating: (0) | mike, the only issue i have with your otherwise good breakdown is your number for compressor outlet temp... it's way, way too high. seriously, that's the absolute worst compressor efficiency EVER. where did 415f come from? was it aps? if so, i can see why, because the higher the delta between ambient temp and compressor outlet temp, the better the intercooler "works." |
| | #34 |
| Authorized Vendor
IWSTI Addict since: Jan 2006 Trader Rating: (0) | That is the actual reading on a real STi. Also remember the outlet pressure was just over 27 psi so it's going to be quite a lot hotter than your average 1 bar setup. You are correct that it's pretty high because the efficiency of the compressor is being pushed. From what I've seen most people do this so it's not out of the ordinary. |
| | #35 |
| The Next Petter Solberg
Car: 06 STI WRB Fav Mod: Defi Gauges Location: Bethlehem PA Posts: 922
IWSTI Addict since: Dec 2004 Trader Rating: (0) | interesting. so subaru would get a much better performing car if they just moved it to the front...So why is it that they keep insisting on the top mounted ic? is it cost? Is it really that much more expensive to run those pipes in an already expensive car? It seems like a no brainer, the 08 should have gotten it. |
| | #36 | ||
IWSTI Addict since: Dec 2005 Trader Rating: (0) | Quote:
![]() i don't know what kind of people go into your shop but the list of folks i know running 27+ psi on vf39s is very, very, very short. ![]() they do this on pump gas? with what, ~10 degrees of timing? if so, i'd hate to see the egts at the end of 4th gear.. ![]() who tunes these cars this way? would YOU tune the car this way? a long time ago (>4 years) a friend of mine did some tests with a td04 at 18psi, and was netting compressor outlet temps in the 200s. your numbers are 200 degrees higher than that, so you can understand my incredulity. | ||
| | #37 |
| Silver Member
Car: 06 CGM Wingless Fav Mod: The Newest One! Location: Ra cha cha NY Posts: 3,562
IWSTI Addict since: Sep 2005 Trader Rating: (0) | How does the math work for this with DEI?! ![]() ![]() On that note.. Great write up Mike! |
| | #38 | |
Stealth 316 - Turbo Outlet Temperature comp efficiency would have to be 53.5% to cause a rise from 70 to 413 degrees at 27psig. | |
| | #39 |
| aka: jnprn2003
Car: 07 STi, 07 Speed 3.. Fav Mod: EFI Logics tunage Location: The Ocean State Posts: 2,533
IWSTI Addict since: Feb 2007 Trader Rating: (13) | |
| | #40 | |
| aka: jnprn2003
IWSTI Addict since: Feb 2007 Trader Rating: (13) | Quote:
| | #41 | ||
| Authorized Vendor
IWSTI Addict since: Jan 2006 Trader Rating: (0) | Quote:
Another key element is packaging. A top mount setup can much more easily be transplanted into various other chassis, while a front mount often requires different piping, core mounting, etc. for proper fitment. Then there's the trademark Subaru hood scoop. It's one of the big things that has set Subaru apart for a long time and no doubt they plan on keeping it. They even put them on the GC8 when it was totally non-functional simply because of branding. I'm sure there's a lot more to it, but those are a few key reasons. Quote:
I never said anything about the boost level I see people running. I said I see tons of people coming in that are pushing the compressor efficiency of their turbo. At 17 psi on a VF39 at 7000 rpm on a 2.5L STi engine you are pushing the compressor map hard and tons of people do that. You can only use pressure as a reference for compressor efficiency when you state an amount of airflow and the compressor in question. When I say 7000 RPM on a 2.5L STi engine with a VF39 that implies an amount of airflow, so that's fine for estimations as well. That calculator is a great find. I used to refer to that site for their fuel pump flow data. I just ran the calculator for two examples: 16G at 21 psi, 100 F underhood temps This is off the compressor map from about 5800 rpm or so on when run on a 2.5L STi, but people do this anyways. At 7000 rpm you're under 50% efficiency, but even if it was as high as 50% efficient, outlet temp from that calculator says 423 F When I tune a small 16G I taper the boost to about 17 psi so efficiency is about 60% at 7000 rpm. That calculator still says the outlet would be 329 F under those conditions and I don't doubt it. Last edited by Inn-Tune; 12-27-2007 at 06:11 AM. | ||
| | #42 | |||
![]() as i suspected it looks to me like aps was painting their example in the most favorable light. Quote:
you can't get away with that on a road course though! | |||
| | #43 | |
| Spec C Club
Car: 04 Crawford STi Fav Mod: CP35r 440whp Posts: 2,063
IWSTI Addict since: Jun 2006 Trader Rating: (3) | Quote:
You put a fmic on the car....you get rid of the bumper beam. This is why Evo's weren't allowed in canada, I believe. Couple that with the reasons already mentioned and you have your reason. I do believe the safety factor is the largest weight in their decision, though. | |
| | #44 |
| Authorized Vendor
IWSTI Addict since: Jan 2006 Trader Rating: (0) | |
| | #45 |
IWSTI Addict since: Dec 2005 Trader Rating: (0) | i have never seen a compressor map for a 16g series turbo with a 50% island on it. you want to post it up and help the community out? ![]() i know you're talking out your ass, but i'll play along anyway; i do enjoy watching people hang themselves, bit by bit. This ad is not endorsed by this member. Please register or login to hide this ad. |
