Old 12-16-2007, 09:02 AM   #16
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
Default Re: My used APS 65mm CAI and my rejuvenation write up
Thanks for the write up. I was actually looking for the part number for a new filter when I found your thread.
Hitman83 is offline   Reply With Quote
Old 12-18-2007, 05:58 AM   #17
Car: '08 WRB SG Model D
Fav Mod: All of them...
Originally Posted by Good2Go View Post
FYI... Amazon.com has the filter for $26 and the pre-filter for $16 with free shipping over $25 spent.
That is where I got mine
Originally Posted by boost3d05 View Post
i have that intake, i love it w/ the protune....its loud and awesome....i cant wait to see how the blue turns out....take your time! but hurry up w/ the pics! haha
Yeah, I want to hurry but this week I am swamped at work and then holiday vacation so probably won't get to this until the new year but I will definitely keep you all posted w/ the progress...don't you worry
Originally Posted by TheLimitedProject View Post
Does anyone know if the filters above are the same for the 65mm and the 70mm APS intakes?
What you do is measure the filter on the 70mm and compare it to the filter dimensions of the RU-3130 (filter I got to replace the APS 65mm filter): LINKY
If it is not the same then you can look on the universal site to find one that works: LINKY
sirwilliam is offline   Reply With Quote
Old 12-18-2007, 10:38 AM   #18
Moderator & ECU Tech
Fav Mod: mo boostaz
APS CAIs actually use to have the K&N filter. They no longer utilize this filter. They utilize a custom filter. Here is the custom filter that all APS CAIs utilize ...
www.bescaredracing.com - /sti/intake/aps/cai/filters/aps/
t
Old 12-18-2007, 11:06 AM   #19
Fav Mod: Pro-Tune
Trader Rating: (16)
Thanks for the information in this thread! My old filter looks EXACTLY like the OP's! This is my Christmas present to my car!
CB
Old 12-18-2007, 12:43 PM   #20
t
Hmm...mine came w/ a K&N filter...so according to your info, the 70mm and 65mm use the same size filter. Thanks!
Old 12-18-2007, 02:29 PM   #21
Fav Mod: mo boostaz
Yes. APS switched out the filters and use a different one now. The new filter is much longer and narrower. The pictures that I took above of the new style filter are from a brand new 65mm unit.
t
Old 12-19-2007, 09:04 AM   #22
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
That prefilter is teh hawtness
TAPOUT is offline   Reply With Quote
Old 12-29-2007, 07:02 PM   #23
STI Guru
Fav Mod: Whooshing sounds
Just got a used APS 65mm CAI.
So is there a way to get the "new" filter from APS or should I just get the K&N?
Old 12-29-2007, 08:45 PM   #24
Is Scared Of Kevin...
i would just get the k&N.....the K&N is much higher quality.......i think that aps cheaped out on the new filters.....
MKTURBO is offline   Reply With Quote
Old 01-01-2008, 12:11 PM   #25
i eat cones
Fav Mod: 18x8
Trader Rating: (16)
i want a used one in the near future. save $ ftw.
Old 01-01-2008, 01:26 PM   #26
STI Guru
APS 65mm CAI - Engine/Power/Exhaust - NASIOC
Old 01-15-2008, 08:37 PM   #27
Car: UGM 2007 STi Limited
Fav Mod: APS SS42 Turbo
t
Do you know which of these filters would fit better in a 2007 fender? I read in this thread that some clips had to be removed because the filter is too long for the 06/07 fender.
Anyone have any measurements on the K&N filter?
Thanks for the help.
CO2.5i is offline   Reply With Quote
Old 01-17-2008, 08:59 AM   #28
Car: 04 PSM STI
Fav Mod: Cusco Products
After about 6months of installing the APS 65mm CAI in my 04sti...I develped this crazy creak/squeak whenever I would dirve at ~50mph+ mostly on the concrete block style of highways...I checked everything so I thought...turns out, the nuts attatching the brass bracket to the inner fender had come off...you really can't tell unless you take off your wheel, open the liner and look in...like when you are cleaning the filter...as was the case.
To fix this, and to isolate the bracket a bit , I bought some rubber washers fom the hardware store...and it seemed to do the trick...not completely.
at high speeds over uneven highway conditions (sudden dips etc) it would still make the noise...the only thing I could think of was that my engine mounts were getting worn...rubber tends to wear prematurely here in Hawaii due to the heat...when I attempted to move the intake pipe (it is a VERY tight fit through the hole), there was a slight movement and I was able to reproduce the sounds slightly...so
I recently installed Cusco engine/transmission mounts on my 04 sti...that did the trick...the extra movement of the engine/trans was now eliminated and I no longer have the squeak...thank goodness.
Island Style is offline   Reply With Quote
Old 01-17-2008, 10:15 AM   #29
STI Guru
IMO, These instructions are vague and misleading.
When you take out the snorkel, you end up with 2 holes in the fender. The one they show in this picture looks like the hole closest to the headlight, which is the wrong hole. I found that out the hard way.
Old 02-05-2008, 07:23 AM   #30
NIИja
******Warning: The RU-3130 K&N filter and APS CAI will NOT fit on an 06/07 STI.******
I just went through this last night. Save yourself the trouble. The OD of the K&N filter is TOO big.
