Old 12-17-2007, 09:58 PM   #16
Car: 2007 OBP STI with Go
Fav Mod: dealer license plate delete
Default Re: Is there a way to pass emissions testing w/ turboback exhaust or uncatted dp?
id say skip the whole mess and slap a stock exhaust on for the test its so much easier
Kylipso is offline   Reply With Quote
Old 12-18-2007, 05:17 AM   #17
Car: 07 OBP STI
Fav Mod: Sundays and Boxers
My bad Scuba, thats actually why I edited it. After I posted it, I looked it over and realized how abrasive it sounded... which was not my intention at all. I was going for humor and it sounded straight mean.
My apologies.
StylesJim is offline   Reply With Quote
Old 06-27-2008, 08:36 AM   #18
Car: 06 WRB STI
Fav Mod: Volk Racing RE30 (Diamond Black)
You can if your inspection shop only does a visual inspection. Hey Scuba I have narrowed my exhaust to the MAdDad whisper full 3". Curious how you were diggin it?
I love the exhaust note...perfect deep boxer rumble without screaming at the neighbors.
I am curious on the 2 piece downpipe. How was fit/finish and if I were going stage 2 would I need a custom tune right away? My shop wont do the COBB protune because of licensing so they want to do a custom map. The dude is awesome but I know with the COBB you can switch between maps and such. Either way should I expect Check engine lights when going stage 2?
Do I need to pick up a fix of some sort?
Thanks if you get this
Regards,
Hammer
TheHammer is offline   Reply With Quote
Old 06-27-2008, 09:33 AM   #19
Car: 06 Subaru WRX STi
Go to the inspection shop with a few $20's sticking out of your pocket and you should pass. Around here in cali first emissions test is read odb port as long as no codes then you are fine.
