Old 10-23-2007, 08:24 AM   #46
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Stock Up-pipe - a more serious look
Originally Posted by IGoFast1589 View Post
How do you know when the inlet and outlet of an aftermarket pipe is TOO big? I still believe that at this point in time it would not be worth if for me to do an up-pipe but, in the future for sure. I have to make some more money and do some other mods first.
At the point where you cause a lip or step in line with the flow of the system.
There are two concerns on the step:
1) When you go from small bore to big bore.
2) When you go from big bore to small bore.
Number one causes a low pressure zone as air "falls" off the small step into the larger space. This will cause turbulence, but is really not as bad as the next situation.
Number two when you go from large bore to small bore, and this is when we're talking about a sharp edge step, not a gradual over a long distance tapering. The flow basically hits a wall and backs up the gasses. This causes a lot of turbulence and causes the air to stall.
The ideal best solution if you want to go from one bore size to another is a smooth taper spread out over an long a distance as you possibly can.
Old 10-23-2007, 09:11 AM   #47
Car: 07 Subaru STi
Fav Mod: Coilovers/Tune
Send a message via AIM to IGoFast1589
That makes perfect sense. Thanks
IGoFast1589 is offline   Reply With Quote
Old 11-03-2007, 09:26 AM   #48
Car: 06 BLACK STI!!!
Fav Mod: Annual Bonus!!
Send a message via AIM to all4bspinnin
please make this a sticky!!
all4bspinnin is offline   Reply With Quote
Old 11-05-2007, 01:59 PM   #49
Car: 35R sti
is the improvment in spool relevent also for a 2.0 engine(20g)?
and finaly-to wrap it?
great thread
avi1777 is offline   Reply With Quote
Old 11-06-2007, 08:43 AM   #50
Car: 35R sti
anybody?
Old 11-06-2007, 08:53 AM   #51
Trader Rating: (53)
great thread
anybody?
Sorry, didn't see until now. Good flow to the turbo is absolutely important even on the 2.0.
Are you using the JDM motor? If so did you get the twinscroll setup at the same time or did you convert to single scroll?
Old 11-06-2007, 10:46 AM   #52
Car: 35R sti
thanks
my set up in single scroll,i know twin is better but im runnig a bolt on,
since i put the headers and up the car is lazyer,i hope once wraped the spool and response will come back.
my motor is stock but soon i'll go stroker2.2
Old 11-06-2007, 10:54 AM   #53
Trader Rating: (53)
thanks
If you're using JDM heads then you need something better flowing than the stock headers. I would think about porting the ends, going with a crosspipe, and doing a nicer UP.
I believe I have a graph around somewhere that shows the JDM STi heads outflowing the USDM STi heads by a decent margin. I'll see if I can find it.
Oh, and if you're gonna spin that 2.2 stroker about 7K then you definitely want as free flowing an exhaust pre-turbo as possible (heck, I guess you could just say that about any of these setups).
Old 11-06-2007, 10:59 AM   #54
Fav Mod: CP35r 440whp
OH! PLEASE find that! I'd like to see it.
Old 11-06-2007, 11:33 AM   #55
Send a message via MSN to RFFG
Subscribed
RFFG is offline   Reply With Quote
Old 11-06-2007, 12:10 PM   #56
Car: 35R sti
[quote=Turninconcepts.com;1590029]If you're using JDM heads then you need something better flowing than the stock headers. I would think about porting the ends, going with a crosspipe, and doing a nicer UP.
you mean porting the heads of the stock headers?
beacuse i allready put the perrin eql,bigger up and ewg and moved to otronic engine manegment from ecutec.
for now(maybe beacuse its not wraped and dont boost beyond1.4bar)i dont feel any improvment on my car what so ever,sad.it even spool slower
and in israel thing coast twice than the states so imagine how i feel
Old 11-07-2007, 12:30 AM   #57
Car: 35R sti
sorry i ment porting the stock ends(not heads)
Old 03-03-2008, 04:51 PM   #58
Car: 05 STi CGM
Fav Mod: JDM Foglights
Originally Posted by BoostJunkie View Post
This is why I ordered the new Grimmspeed uppipe. It only has a single bend, 10mm flanges, the ID is a perfect match to my GT52 (I will port the outlet on the manifold accordingly), and the flex section is at the bottom, minimizing turbulence at the point where the exhaust enters the turbo. I think it's the best piece available right now.
I ordered a grimmspeed upipe from TIC and it definitely has 2 bends. bends are more like the first one pictured here:
http://www.grimmspeed.com/images/pro...tors_500_1.jpg
Here's a pic of a PRODUCTION Grimmspeed. Its a nice piece but def 2 bends.
SCOOBYTRAP is offline   Reply With Quote
Old 06-15-2008, 05:04 PM   #59
07 OBP STi Owner
Car: 07 OBP WRX STi
Fav Mod: The ones I install myself!
Thanks for all the info in this thread, I was waiting to do the 'before' turbo set up, but now I am convinced that this would be a good next step. By the way, if any has read it, Modified mag did an article (January 2008) by AMS on an STi. The following numbers where for what they did on the dyno:
4wd Dynojet
Stock VF39 (14psi): 258whp / 261ft lbs
Remap (19psi ~ 15/16psi by redline): 285whp / 317ft lbs
AEM CAI (19psi): 295whp / no torque reading
Turbo XS Downpipe: 301whp / 337ft lbs
Manual boost controller remap (19.5psi): 311whp / 355ft lbs
TGV Delete: 318whp / 360ft lbs
Remap (21psi ~ 15psi at redline): 328whp / 370ft lbs
Vibrant header + up-pipe (19.5psi~15 at redline): 343whp / 404ft lbs
Gains over stock: 85whp / 141ft lbs
These numbers all had dyno graphs, and this was done with the stock VF39 turbo, fuel pump and injectors.
Rasz's STi is offline   Reply With Quote
Old 06-20-2008, 03:47 AM   #60
Car: 07 STi LTD
Fav Mod: HKS Carbon Ti
ooo, that 404 looks tantalizing.
Dirty Bird 15 is offline   Reply With Quote
