Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Closed Thread
Old 07-10-2008, 03:59 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default Helix Downpipes In Stock-Free Up-Pipe With Manifold
There here guys! Helix Downpipes in stock. Also all Gruppe-S manifolds come with a free Helix Up-Pipe. Also Dont miss out on our awesome turbo combos in stock ready to ship.
Helix Downpipes
In Stock Ready To Ship
Non-Catted Downpipe $225 Shipped
Catted Downpipe $349 Shipped
****Coming Soon Helix Downpipes for 2008 WRX/ STi****
Helix Turbo Back Exhaust
Performance Exhaust
Helix Non-Catted DP/HKS Hi-Power- $725 shipped
Helix Catted DP/HKS Hi-Power- $825 shipped
Helix Non-Catted DP/HKS HKS Carbon-Ti- $775
Helix Catted DP/HKS HKS Carbon-Ti- $949 shipped
Helix Catted DP/GReddy TI-C- $725 shipped
Helix Non-Catted DP/Blitz NUR Spec- $849 shipped
Helix Catted DP/Blitz NUR Spec- $725 shipped
Quiet Exhaust Under (93db)
Helix Non-Catted DP/A'Pexi World Sport- $675 shipped
Helix Catted DP/A'Pexi World Sport- $799 shipped
Helix Non-Catted DP/Apexi WS NOIR- $699 shipped
Helix Catted DP/Apexi WS NOIR- $825 shipped
Helix Non-Catted DP/GReddy SP2- $975 shipped
Helix Catted DP/GReddy SP2- $849 shipped
Helix Non-Catted Dp/Tanabe Medalion Touring- $725 shipped
Helix Catted Dp/Tanabe Medalion Touring- $849 shipped
Gruppe-S Exhaust Manifold
Free Helix Up-Pipe
The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. The outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly
Constructed from T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. Dyno proven to make up to 8hp and 12 ft-lbs of torque. The design of the Gruppe-S equal length manifold increses boost response. Spool up time is decreased incresing boost pressure at lower RPM's. Due to the exhaust pulses now being paired together the lumpy boxer sound is lost instead a smoother sound is produced.
****2.0L Engines Require 2.5L Oil Pan For Manifold Clearance****
Un-Equal
***Free Helix Up-Pipe***
$425 Shipped
Equal Length
$649 Shipped
BC Cams
Free Gruppe-S Lightweight Crank Pulley
After months of testing the BC camshafts are finally available.
Stage 2 (272)-Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM springs OK.
Stage 3 (280)- Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires spring kit.
WRX 272
WRX 280
STi 272
STi 280
PM For Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor)
Dont Forget to Add
BC Valvetrain Components
Brian Crower Spring/Retainer Kit
$225 Shipped
Brian Crower Intake/Exhaust Valves
$249 Shipped
Looking for a complete BC Drivetrain Combo?
Engine Rebuild Kits
EJ20 Engine Combo/ EJ25 Engine Combo
Good Up To 600 whp
-CP (standard size) or (+020 overbore) Pistons
-CP Piston Rings
-Helix Forged Rods
-Coated Race Bearings
$799 Shipped
EJ25 Budget STi Engine Rebuild Kit
-USDM STi Pistons
-USDM STi Piston Rings
-USDM STi Rods
-USDM STi Bearings
$499 Shipped
V34 Turbo Package
+40 WHP Upgrade
The IHI VF-34 Turbo is found on the limited production Subaru v7 WRX STI-RA (GDB). This turbo is differentiated from the VF30 through it's more advanced bearing design. The bearing design allows for much quicker turbo spool-up (depending on tuning, 300-500+ RPMs over the VF30), while retaining the power capabilities of the VF30. The VF34 is capable of 350+ HP (~300+whp) This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines. This is an excellent replacement turbo for those looking for substantial power gains while maintaining streetability.
- IHI VF34 Turbo
- STI 565cc Injectors,
- Walbro GS342 Fuel Pump w/ setup kit
IHI VF34 Turbo 375HP Package
Now $1375 Shipped
VF34 Turbo
$899 Shipped
MHI 18G Turbo 400HP Package
+50 WHP Upgrade
The new MHI TD05H 18G turbo for Subabru WRX. With 7cm2 turbine housing, also included are water lines and oil drain line. This high-powered upgrade is good for 400 HP and flows 600 cfm! 1yr warranty. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines.
-MHI 18G Turbo
- PE 650 or 800 cc Injectors,
MHI 18G Turbo 475HP Package
$1999 Shipped
MHI 18G Turbo
$749 Shipped
ATP GT30 Turbo
450HP Package
In Stock!!!
Xtreme EVO Killer System
-GT3076R/ or GT3071R Turbo
-Hydra EMS
-Perrin 3" Turbo Inlet Pipe
-Denso 860cc Injectors
-Walbro 255 lph Fuel Pump - w/ Setup Kit
$3999 Shipped to the door.
Pro Max System
-Cobb Accessport
$3199 Shipped
Street System
-Cobb Accessport
$2950 Shipped
ATP GT3076R/ or GT3071R Turbo
$1799 Shipped
Gruppe-S is offline
Old 07-11-2008, 10:36 AM   #2
Trader Rating: (13)
Default Re: Helix Downpipes In Stock-Free Up-Pipe With Manifold
Hey guys I have a few awesome Open Box Specials
Limited Quantities available so Act now.
Perrin STi (04-06) Fuel Rail Combo
1 At This Price
1- Perrin Side Feel Fuel Rails
4- Helix 860cc Injectors
1- Walbro 255 Fuel Pump Kit
$750 Shipped
Perrin Turbo Inlet
1 At This Price
Red Silicone Left In Stock
$175 Shipped
Spearco TMIC
Save $$$ Over Brand New
Brand New Display Units no Damage At All
WRX/ STi $725 Shipped
Gruppe-S Pulley Combo
Save 5.4 lbs. Of Rotating Mass
AEM Alternator Pulley
AEM Alternator Belt
$125 Shipped
Gruppe-S is offline
Old 07-14-2008, 11:22 AM   #3
Trader Rating: (13)
Gruppe-S is offline
Old 07-15-2008, 09:39 AM   #4
Trader Rating: (13)
Gruppe-S is offline
Old 07-16-2008, 09:33 AM   #5
Trader Rating: (13)
Gruppe-S is offline
Old 07-16-2008, 09:38 AM   #6
Trader Rating: (13)
Gruppe-S is offline
Old 07-17-2008, 12:07 PM   #7
Trader Rating: (13)
Gruppe-S is offline
Old 07-18-2008, 01:09 PM   #8
Trader Rating: (13)
Gruppe-S is offline
Old 07-21-2008, 10:19 AM   #9
Trader Rating: (13)
Gruppe-S is offline
Old 07-21-2008, 11:20 AM   #10
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
Helix have 08 STI fitment?
mofoSTI is offline
Old 07-21-2008, 12:46 PM   #11
Trader Rating: (13)
Sorry but I belive you have already asked me 3 or 4 times in the past month.
Helix does not have a version available at this time. It is currenty in development stages.
Thanks
Ben
Gruppe-S
Gruppe-S is offline
Old 07-21-2008, 01:01 PM   #12
Sorry I am a painter and I hardly even remember my last thought. The 08's have only a few dp's to chose from cobb, invita, and perrin. I had a Helix on my last STI ( suprised I remember that ) and thought I would ask because you never know if a vendor like you knows if something is comming down the line.
thanks
mofoSTI is offline
Old 07-22-2008, 10:31 AM   #13
Trader Rating: (13)
Gruppe-S is offline
Old 07-23-2008, 11:39 AM   #14
Trader Rating: (13)
Gruppe-S is offline
Old 07-24-2008, 11:37 AM   #15
Trader Rating: (13)
Gruppe-S is offline
Closed Thread
