Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Closed Thread
Old 06-27-2008, 08:37 AM   #1
Car: Where Real Power is
Fav Mod: Tuning & Performance
Default AMR - Turbo XS Delta v2.0 UTEC for 02-05/06-07 WRX & 04-07 & 08 STi
Turbo XS Delta v2.0 UTEC Engine Management for WRX & STi
The Turbo XS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions.Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions.UTEC Standard
Features:
PLUG & PLAY: Installs in minutes on top of the factory computer using all the factory connections.
END-USER PROGRAMMABLE: Fine tune maps via a laptop equipped with a serial cable and Hyperterminal.
PRE-PROGRAMMED BASE MAPS: Standardized maps are available for common setups (i.e. turboback exhaust, upgraded intercooler, bigger turbo & injectors, etc.) Maps can be uploaded and downloaded easily. Not currently available for the Legacy GT.
5 MAP MEMORY: 5 maps can be stored at a time, and using the remote map selector, you can quickly switch into valet mode, stock mode, nitrous, or race fuel maps with the click of a switch.
FUEL, TIMING, AND BOOST ARE USER-PROGRAMMABLE: in 250rpm increments up to 9000rpm over 10 load sites.
COMPLETE IGNITION TIMING CONTROL: No need to worry about the factory ECU pulling timing anymore; be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map
FUEL CONTROL: Controlled via MAF sensor signal offset, tune stock and larger than stock injectors; pre-set injector correction (just type in the size!).
LOAD REFERENCE: MAP (manifold pressure)
CLOSED LOOP BOOST CONTROL: Programmable via throttle Position and RPM. No more re-adjusting the boost controller due to changes in temperature or altitude. Keeps boost low while in closed loop fuel mode for reliability.
KNOCK CONTROL: Automatically retards timing when the knock is detected safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration.
ON-BOARD DATA LOGGING: Displays all necessary data required for tuning, including wideband AFR when used in conjunction with the Turbo XS Tuner.
BUILT-IN PROGRAMMABLE SOLENOID CONTROLLER: Control nitrous, water injection, intercooler water spray or any other solenoid device.
ADDITIONAL FEATURES: Drag racing launch control (secondary rev limit used during launch). All UTEC software downloads and upgrades are free and available from Turbo XS's website.
1 YEAR WARRANTY
FITMENT:
2002-07 WRX
2004-07 STi
Delta Utec 02-05 WRXtxs-DELTA-001
Delta Utec 04-06 STitxs-DELTA-002
Delta Utec 06-07 WRXtxs-DELTA-003
MSRP - $1046
Our Price - $944
_________________________________________________
Turbo XS Delta v2.0 UTEC Engine Management for STi
The Turbo XS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions. Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions.UTEC Standard Features:
FITMENT:
2008-00 STi
Delta Utec 2008-09 STi txs-DELTA-003
MSRP - $1046
Our Price - $944
Please pm us with any questions or Visit automasteramr.com
AutoMaster is offline
Old 07-01-2008, 10:27 AM   #2
Default Re: AMR - Turbo XS Delta v2.0 UTEC for 02-05/06-07 WRX & 04-07 & 08 STi
Bump!
Closed Thread
