Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Closed Thread
Old 06-26-2008, 06:22 AM   #1
Car: Where Real Power is
Fav Mod: Tuning & Performance
Default AMR - 2008 STi - BMI,Stage 1,TMIC,750CC Injectors,T50R Turbo,New 19-24psi Acuator
2008 AMR BMI System
$299.99
MADE IN THE USA!
The AMR BMI Cold Air System is hand built in-house to ensure fitment and quality. All of the BMI Systems come coated in either wrinkle red or our custom silver flake..
SPECS:
The *NEW* AMR Big Maf Cold Air Intake System is one of many products lined up for the new 2008 season. This intake has a diameter of 74mm making it one of the biggest on the market. Taking advantage of the 2008's unique body style, we have designed a cold air system giving the vehicle fresh air rather then under the hood absorbing excessive heat from the engine.
WHAT DOES IT COME WITH?
This intake system comes with "coated" intake piping, silicone couplers, clamps, bracket, and K&N cone!
COLORS / OPTIONS:
This intake system is available in wrinkle red and, as shown above, our custom silver flake.
*NOTE:
The AMR BMI System is 70mm+ in diameter. You will need to either run our AMR S1 map or a custom tune in order to scale the correct air to fuel mixture. Otherwise the vehicle will run lean and cause mechanical problems.
The new style 2008 STi has come a long way from its older brothers. With the new AVCS Exhaust Cams and extremely intelligent ECU. The 2008 STi is one of perfection. We at AMR have our own 2008 STi in house in which all testing and product development takes place. AMR S1 Package has sling shot the new 2008 STi into the high 12's in the quarter mile. Making the 2008 AMR STi first in the 12's.
AMR Stage 1
Our AMR-S1 Kit gives you a healthy increase in power. Not only in drivablilty, but an noticeable increase all through out the RPM band.
Stage 1:
Track E.T.: 12.9 - 13.2
Track MPH: 108mph-110mph
Modifications:
1) COBB AccessPort v2.0
- Custom AMR Map
2) AMR BMI Cold Air System
$1,199.99
AMR 750cc Injectors
$699.00
The AMR 750cc Injectors right on the money. Tested and flowed to a perfect 750cc. These injectors are as top quality as you can get. Nothing over looked. Complete plug-n-play for easy installation. No HARD wiring under the hood.
These injectors are included in our staged packages along with a custom dyno tuned map. Making everything a complete plug-n-play. So your only down time on the vehicle would be the parts install.
AMR T50R Turbocharger (bolt-on)
$1899.99
One of the most fun drivable turbochargers on the market. Achieving full boost around 3000rpm-3600rpm (depending on modifications) causes the driver to get extremely throttle happy! Designed for those who want that QUICK SPOOL and TOP END POWER. The AMR T50R has a fully ported compressor housing and fully ported 7cm2 exhaust housing giving the turbocharger maximum flow. Along with the optional 3" compressor housing, this turbocharger is a fully done 50 trim jammed with all of the goodies making it the best bang for the buck! Power levels range in the 330whp-400whp mark.
T50R Specs:
- 750-770 cfm
- 7cm2 exhaust housing
- 2.4" Compressor Inlet (optional 3" compressor inlet)
- Fully ported exhaust housing
- Fully ported compressor housing
- HIGH TEMP coated exhaust housing (increase spool time)
- OIL AND WATER COOLED!
- Includes ALL oil and water lines
- DIRECT BOLT-ON
OPTIONAL CUSTOM 19-24 psi Acuator
$190.00
Optional:
Just when you think it couldn't get any better. We can include the optional 19-24psi Custom Built Actuator for an addition $190.00. This actuator is for those running heavy boost. This wastegate combined with the T50R makes boost taper a thing of the past. We have tested the T50R with this actuator holding boost straight to redline.
The CUSTOM actuator made for our T50R by FORGE is a thing of beauty.
AMR Top Mount Intercooler (TMIC)
20"L x 12"W x 4"H
$899.99
The AMR Top Mount Intercooler (TMIC) puts the stock intercooler to shame. With a dimension of 20"L x 12"W x 4"H it dominates over the stock tmic. The AMR TMIC is designed to cool down the air charge to the engine which in turn gives the vehicle better response, more torque and more power. The AMR TMIC has been tested at over 30+ psi.
FITMENT:
PERFECT! No fighting with clamps, brackets or fire wall issues. Intercooler's are fully assembled. All T-Bolt clamps, gaskets and couplers included. So just take it out of the box and slip it on the car.
FEATURES:
The AMR TMIC really differs from others. The intercooler is upgraded with a 3" outlet rather than the 2.5" that comes standard on competitors. Allowing more room for air to travel out of the core into the engine.
We have noticed with upgraded turbochargers, the upper coolant line hits the intercoolers. So we have modified a inverted lip on the end tank.
We also BEEFED up the material used on the flanges. Making them practically un-bendable. All flanges are made from 6061 aluminum.
COLOR CHOICES:
- BLACK w/ AMR logo in white
- Brushed Aluminum w/ AMR logo in black
VISIT AutomasterAmr.com OR PM ME WITH ANY QUESTIONS!!!!
AutoMaster is offline
Old 07-01-2008, 10:28 AM   #2
Default Re: AMR - 2008 STi - BMI,Stage 1,TMIC,750CC Injectors,T50R Turbo,New 19-24psi Acuator
BUMP for new 2008 parts!!!!!!
Closed Thread
