Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Old 06-14-2008, 09:38 AM   #1
Car: 03 Evolution 8
Trader Rating: (16)
Default 201 Motorsports POWER DEALS! Perrin/Cobb/Beatrush/Invidia/Megan Racing/Element Tuning
201Motorsports is offline   Reply With Quote
Old 06-14-2008, 09:39 AM   #2
Car: 03 Evolution 8
Trader Rating: (16)
Default Re: 201 Motorsports POWER DEALS! Perrin/Cobb/Beatrush/Invidia/Megan Racing/Element Tu
Perrin Sport Tone Exhaust System Single Tip WRX/STi
Perrin Performance's Single-Tip catback exhaust is designed to provide optimum exhaust flow for your 2002-2007 WRX or 2004-2007 STi. This awesome catback has a 4" tip and utilizes 3" piping throughout without tapering at the downpipe. This exhaust will mate up to any aftermarket 3" downpipe. The Perrin Single-Tip catback is constructed of stainless steel, is fully flanged, and is finished in high polish for some added flash. The Perrin Single-Tip has a resonator built in to reduce droning without draining power from the boxer engine.
Price: $589 shipped
Old 06-14-2008, 09:39 AM   #3
Car: 03 Evolution 8
Trader Rating: (16)
IN STOCK @ 201 Motorsports
Cobb Tuning AccessPort v2.0 2.5L- $695 shipped
*FREE 1-DAY DELIVERY*
Cobb Tuning AccessPort v2.0 2008 WRX/STi/LGT- $695 shipped
Here's some more info about the AccessPort 2.0:
The AccessPORT by COBB Tuning, Inc. is a handheld programmer that allows you to unlock your vehicle's hidden potential by reprogramming the stock Engine Control Unit (ECU).
With a short and guided installation process you can upgrade the ECU in your car from stock to one of our performance oriented tuning maps. The unit uses the OBD-2 diagnostic port, and requires no cutting, wiring, or other such modifications, simply plug-and-play.
The crowning function of the AccessPORT is COBB's unique 'Real-Time' mapping, which allows you to change the tuning data within seconds, as opposed to minutes. Simply park, switch realtime, and resume driving, it's literally that easy.
Using our off-the-shelf staged maps, the AccessPORT can unlock the potential of your vehicle by as much as 50hp, and more based on further modifications. The possibilities are endless since the AccessPORT is a short ProTUNE away from giving your car even more potential from the staged maps.
The AccessPORT's features include:
» On-the-fly map switching
» Monitor vehicle sensor data and display in analog or digital format
» Vibrant color graphic display with First-Ever full 260,000 color OLED, high-resolution screen
» Read/Clear engine trouble codes
» Preloaded with performance, economy and convenience maps
» Update via the Internet
» Measure 0-60 and ¼ mile times
» Adjustable on-screen Shift Light functionality
» Estimates horsepower and torque
» Displays current and averaged fuel economy
» Drag race simulation with reaction time and “time slip” data
» Built in on-screen help mode function
» Multi-Language support
» RoHS compliant (Lead Free design)
» Custom performance tuning for your specific vehicle and modifications as provided by an
authorized AccessPORT ProTUNER™ center
Price: $695 SHIPPED (1 Day Delivery)
Old 06-14-2008, 09:40 AM   #4
Car: 03 Evolution 8
Trader Rating: (16)
Beatrush @ 201 Motorsports
With years of experience in motorsports, Laile, (which manufactures, brands, and operates Beatrush) has collected sufficient data information on the tracks of Japan to produce high quality and functional products. Located in Yokohama, Japan; Laile manufactures most of their product's brands like Beatrush and Arpsports with their high precision machinery. All the unique products developed by Laile offer superior safety and plenty of pleasure both in track and the street, as well to look at.
Beatrush Pulley Cover
# Built to replace the stock plastic piece with a lighter and stronger aluminum piece to better protect the pulleys from dirt and grim due to heavy driving.
# Designed by Beatrush Japan for the 2002-Up Subaru WRX & STI GDB~.
# A+ fitment and made of 1.2 mm-thick Aluminum with a Gold Alumite Finish to prevent rust.
Price: $70 shipped
Beatrush 2006+ Radiator Cooling Plate
# Fits 06-07 Subaru Impreza WRX and STi.
# Developed for the purpose of redirecting air to help cool down the radiator.
# Track tested for functionality.
# Developed by Beatrush Japan.
Price:
$120 shipped
Beatrush Engine Mount 2002-2007 WRX/STi
BEATRUSH Steel Engine Mount with Urethane Bushing
* Reduces excessive motion of your motor during hard acceleration, deceleration, and cornering.
* Stronger Mounts compared to stock.
* Improves shifting feel and on and off throttle response.
* After installation interior vibrations may occur
Track tested for functionality by Beatrush of Japan. Fits 02-07 WRX and 04-07 STi
Price: $195 shipped
Old 06-14-2008, 09:40 AM   #5
Car: 03 Evolution 8
Trader Rating: (16)
Element Tuning @ 201 Motorsports
Element Tuning 3" Full Turboback 2002-2007 WRX/STi
What separates our downpipe from the rest is that we chose to do something new with the divorced wastegate design. I penned this design almost 5 years ago but finding a manufacturer to produce the system with the quality we wanted proved difficult until now. Since the majority of Element Tuning customers have extensive modifications such as larger bolt-on turbochargers like the GT52 or GT49 we designed this exhaust system to exploit that by running the 3” dowpipe’s centerline on the exhaust wheel and the 2” wastegate dump tube’s centerline with the wastegate flapper valve. To do this is difficult however and required us to intersect the 3” DP with the 2” dump tube. You basically end up with almost the volume of a 5” DP and then the wastegate dump tube follows all the way down to the bottom of the exhaust system where we then angled the dump tube to create a low pressure area, therefore creating a Venturi Effect which further aids in proper wastegate flow.
The other item we altered from the norm was a divider at the turbocharger flange. The reason we did this was that we found in testing that it hurt wastegate performance since the majority of the aftermarket turbochargers swing open in a fashion that dumps wastegate exhaust directly into the divider hurting flow. This is often why “bellmouth” designs have better boost pressure control. Also by forgoing this divider, the system will work with turbochargers that have a divided exhaust housing from the factory.
The catback is similar to the Espelir JGT500 (which was discontinued long ago) and has awesome flow capabilities along with fantastic sound! Check out the YouTube link below to hear it:
YouTube - Element Tuning Turboback Exhaust, In-Car
Price: $1099 shipped
Old 06-14-2008, 09:41 AM   #6
Car: 03 Evolution 8
Trader Rating: (16)
Invidia Catless Divorced Wastegate Downpipe WRX/STi
*1 IN STOCK*
For a strong boost in power, the Invidia Down Pipe offers an alternative to other power-boosting enhancements. To see just how much power the Invidia Down Pipe can produce, a quick look at its dyno chart shows it easily added several horse-power units to the stock exhaust system. Each Invidia Down pipe features a large 4-in stainless-steel bellmouth, divorced wastegate to enhance power by freeing excess gas. It sports a one -piece design, eliminating the need for the stock catalytic converter. In addition, each Invidia Down Pipe can be bolted up to any Invidia Exhaust or a stock exhaust for an easy installation.
Price: $279 shipped
Invidia N1 Catless Racing Catback WRX/STi
The Racing and Regular systems feature 3" stainless steel piping, and 4" tips. They both utilize the same "N1" style muffler, and the major difference between the two is the midpipe. The Regular catback has a resonator, and flex section while the Racing midpipe is a straight though with no restrictions for optimal flow.
Price: $525 shipped
Old 06-14-2008, 09:41 AM   #7
Car: 03 Evolution 8
Trader Rating: (16)
Megan Racing Catback Exhaust 2002-2007 WRX/STi
* 4" Flat tip with removable double-layer silencer, 3" piping
* 100% stainless steel with polish finish
* Fits stock down pipe or 3"
* Producing strong, deep and noticeable sound
* Gain more horsepower, faster response, averaging 10-15 extra hp
* Comes with gaskets - Warranty included
Price: $410 shipped
Megan Racing Downpipe 2002-2007 WRX/STi
Megan Racing Stainless Steel Downpipes are made of the same High-Quality T-304 that is featured in our Headers and Turbo Manifolds for extreme durability and resistance to corrosion and cracking. The missing component between any Header/Manifold and your Cat-Back system, these Downpipes will give you the high-flow exhaust system that you desire. With a noticeable power gain and polished finish, these are a perfect touch for any performance vehicle. (Note: For off-road use only, not intended for use on public highways.
Price: $199 shipped
Megan Racing Turboback 2002-2007 WRX/STi
Price: $585 shipped
Old 06-15-2008, 10:49 AM   #8
Car: 03 Evolution 8
Trader Rating: (16)
Happy Father's Day!!
Old 06-16-2008, 11:54 AM   #9
Car: 03 Evolution 8
Trader Rating: (16)
In stock
Old 07-03-2008, 05:38 AM   #10
Car: 03 Evolution 8
Trader Rating: (16)
To the top!
