Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Closed Thread
Old 05-15-2008, 04:50 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default Turbo Combos 40+hp-Spearco TMIC Open Box Sale-BC Cams In Stock-APS Back!
Turbo Combos now available! Get your complete solution. Easy 40+ Hp with these bolt on kits. BC cams are now here!!!! after months of waiting they are finally shipping. These are going fast so act now. All prices Beat. Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor). Spearco TMIC on sale price these are brand new open box display models. Also now in stock Cosworth cams. Combo it up with BC valves, springs and retainers. Back in stock Gruppe-S Unequal Length Manifolds. Limited supplies in stock so act now.
V22 Turbo Package
+40 WHP Upgrade
The IHI VF22 is a DIRECT bolt-on upgrade for your WRX. The turbo makes big power! The VF22 adds mid-range punch as well as vastly-better top-end performance vs. the factory Mitsubishi TD04. Typical gains are 20% in peak horsepower, and a whopping 30% gain in torque over the stock turbo at redline! BIG compressor housing means lots of nice cool air, even at relatively high (20 psi+) boost pressures.
- IHI VF22 Turbo
- STI 565cc Injectors,
- Walbro GS342 Fuel Pump w/ setup kit
- Spearco TMIC
IHI VF22 Turbo 375HP Package $2375 Shipped
Now $2025 Shipped
VF22 Turbo $799 Shipped
Now $749 Shipped
MHI 18G Turbo 400HP Package
+50 WHP Upgrade
The new MHI TD05H 18G turbo for Subabru WRX. With 7cm2 turbine housing, also included are water lines and oil drain line. This high-powered upgrade is good for 400 HP and flows 600 cfm! 1yr warranty. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines.
-MHI 18G Turbo
- PE 650 or 800 cc Injectors,
- Spearco TMIC
MHI 18G Turbo 475HP Package
$1999 Shipped
MHI 18G Turbo
$749 Shipped
ATP GT30 Turbo
450HP Package
Xtreme EVO Killer System
-GT3076R/ or GT3071R Turbo
-Hydra EMS
-Perrin 3" Turbo Inlet Pipe
-Denso 860cc Injectors
-Walbro 255 lph Fuel Pump - w/ Setup Kit
$3999 Shipped to the door.
Pro Max System
-Cobb Accessport
$3199 Shipped
Street System
-Cobb Accessport
$2950 Shipped
ATP GT3076R/ or GT3071R Turbo
$1799 Shipped
Spearco Top Mount Intercooler
***Open Box Display Model***
Spearco TMIC Kit 02-07 WRX
Free Gruppe-S Intercooler Y-Pipe for WRX
MSRP $1199
$749 Shipped
Spearco TMIC Kit 04-07 STi
MSRP $1199
$725 Shipped
BC Cams
Now Available
After months of testing the BC camshafts are finally available.
Stage 2 (272)-Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM springs OK.
Stage 3 (280)- Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires spring kit.
WRX 272
WRX 280
STi 272
STi 280
PM For Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor)
Dont Forget to Add
BC Valvetrain Components
Brian Crower Spring/Retainer Kit
$225 Shipped
Brian Crower Intake/Exhaust Valves
$249 Shipped
Looking for a complete BC Drivetrain Combo?
Cosworth Cams
In Stock Ready to Ship!!
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs or the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new chill cast billet and finished using the same procedures we use in our extreme level race engines.
WRX 275
$975 Shipped
STi 278
$999 Shipped
Helix Easy HP Combo
Gains of up 30 whp+ (with proper tunning)
-Helix Non-Catted DP
-Gruppe-S Unequal Length Manifold
-Helix Up-Pipe (Non-EWG Version)
-Free CEL Fix
$625 Shipped
Combo with Gruppe-S Equal Length Manifold
$749 Shipped
Gruppe-S V2 Manifold w/ Ceramic Coating
The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. The outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly
$575 Shipped
Gruppe-S Equal Length Exhaust Manifold w/ Ceramic Coating
Free Helix Up-Pipe
Constructed from T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. Dyno proven to make up to 8hp and 12 ft-lbs of torque. The design of the Gruppe-S equal length manifold increses boost response. Spool up time is decreased incresing boost pressure at lower RPM's. Due to the exhaust pulses now being paired together the lumpy boxer sound is lost instead a smoother sound is produced.
2.0L Engines Require 2.5L Oil Pan For Manifold Clearance
WRX/ Legacy/ Forester/ STi 2.5L
$799 Shipped
WRX/ Forester/ Legacy 2.0L
$875 Shipped (STi Oil Pan Included for Propper Clearance)
Gruppe-S is offline
Old 05-15-2008, 04:51 PM   #2
Trader Rating: (13)
Default Re: Turbo Combos 40+hp-Spearco TMIC Open Box Sale-BC Cams In Stock-APS Back!
New Helix Up-Pipe
- 44mm id
- stainless steel construction
- robotic tig welded flanges
- machined flanges
$125 Shipped
Helix Down-Pipes
Non Catted
$199 Shipped Free CEL Fix
Catted
Sold out. ETA End Of April
Create your Custom Turbo Back Exhaust
Performance Exhaust
Helix DP/HKS Hi-Power- $699
Helix DP/HKS HKS Carbon-Ti- $775
Helix DP/GReddy TI-C- $640
Helix DP/Blitz NUR Spec- $699
Quiet Exhaust Under (93db)
Helix DP/A'Pexi World Sport- $625
Helix DP/Apexi WS NOIR- $675
Helix DP/GReddy SP2- $699
Helix Dp/Tanabe Medalion Touring- $699
Helix Intercooler Y-Pipe
The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing and increasing the airflow, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs.
$75 Shipped
Engine Rebuild Kits
EJ20 Engine Combo/ EJ25 Engine Combo
-CP (std) or (+020) Pistons
-CP Piston Rings
-Helix Forged Rods
-Coated Race Bearings
$799 Shipped
EJ25 Budget STi Engine Rebuild Kit
Brand new components. Taken out of a brand new USDM EJ257 STi Shortblock. Brand new with zero miles.
-USDM STi Pistons
-USDM STi Piston Rings
-USDM STi Rods
-USDM STi Bearings
$599 Shipped
APS CAI
The APS smooth bore cast aluminium cold air intake system and air filter delivers a huge volume of cold air to the turbo charger for maximum engine performance.
This APS cold air intake system is certainly the most cost effective way to achieve greater air flow, great looks and fantastic sound for your sedan or wagon.
$325 Shipped
APS Turbo Inlet
The APS Turbocharger Inlet Pipe however is precision manufactured in stainless steel and the thin wall tubing (when compared to silicon hoses) delivers the maximum possible internal sectional area for the highest turbocharger air flow. In addition, the strong pipe walls completely solves the problems of hose collapse when under suction at high air flow rates.
$299 Shipped
APS D/R 525 FMIC
The legendary APS front mount intercooler has quickly become the benchmark for all front mount intercooler systems for the Impreza WRX. Extremely high flow rates and massive temperature reduction - a level of performance that other manufacturers can only aspire to achieve.
APS has now upped the ante even further with the release of the D/R 525 front mount intercooler system, specifically designed for high horsepower Subaru WRX and STI engines.
Silver $1650 Shipped
Black $1650 Shipped
APS TurboBack Exhaust Systems
3" & 3.5" Single Tip
3.0" $1350 Shipped
3.5" $1575 Shipped
Gruppe-S is offline
Old 05-16-2008, 10:17 AM   #3
Trader Rating: (13)
Hey guys I have a sweet deal on a Helix 38mm wastergate.
Helix 38mm External Wastegate
Hey Guys I got a sweet deal on a Helix 38mm external wastegate. This was a sample we got from Helix but decided not to carry it. Sold as its.
$120 Shipped
Gruppe-S is offline
Old 05-19-2008, 10:26 AM   #4
Trader Rating: (13)
Gruppe-S is offline
Old 05-19-2008, 10:41 AM   #5
Fav Mod: Too Hard to Choose!
are the BC or cosworth cams AVCS?
IStoSTI is offline
Old 05-20-2008, 10:49 AM   #6
Trader Rating: (13)
Gruppe-S is offline
Old 05-20-2008, 10:50 AM   #7
Trader Rating: (13)
Yes they are for AVCS system.
Thanks
Gruppe-S
Gruppe-S is offline
Old 05-21-2008, 10:37 AM   #8
Trader Rating: (13)
Gruppe-S is offline
Old 05-22-2008, 11:57 AM   #9
Trader Rating: (13)
Gruppe-S is offline
Old 05-23-2008, 10:42 AM   #10
Trader Rating: (13)
Gruppe-S is offline
Old 05-25-2008, 08:08 AM   #11
Car: Blue 06 WRX STi
hey is there a website i can look at all this stuff?? cuz i need parts for a rebuild on my 06 impreza sti
scoobyracer369 is offline
Old 05-27-2008, 11:19 AM   #12
Trader Rating: (13)
Our website is
GRUPPE-S
Thanks
Ben
Gruppe-S
Gruppe-S is offline
Old 05-27-2008, 03:06 PM   #13
Trader Rating: (13)
Bad News Guys! Greddy just informed us that all Greddy will be going up in price (20% increase )effective June 1st 2008.
Cutoff sate to order Greddy at Gruppe-S low prices expires Thursday May 29,2008. PST
Act now before prices go up.
Gruppe-S is offline
Old 05-28-2008, 09:40 AM   #14
Trader Rating: (13)
Gruppe-S is offline
Old 05-29-2008, 09:22 AM   #15
Trader Rating: (13)
Gruppe-S is offline
Closed Thread
