Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-31-2008, 05:45 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default BC Cams Now Available-Cosworth InStock-Unequal Length Manifolds-Turbo Back Combos$625
Hey guys BC cams are now here!!!! after months of waiting they are finally shipping. These are going fast so act now. All prices Beat. Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor). Also now in stock Cosworth cams. Combo it up with BC valves, springs and retainers. Back in stock Gruppe-S Unequal Length Manifolds. Limited supplies in stock so act now.
BC Cams
Now Available
After months of testing the BC camshafts are finally available.
Stage 2 (272)-Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM springs OK.
Stage 3 (280)- Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires spring kit.
WRX 272
WRX 280
STi 272
STi 280
PM For Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor)
Dont Forget to Add
BC Valvetrain Components
Brian Crower Spring/Retainer Kit
$225 Shipped
Brian Crower Intake/Exhaust Valves
$249 Shipped
Looking for a complete BC Drivetrain Combo?
Cosworth Cams
In Stock Ready to Ship!!
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs or the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new chill cast billet and finished using the same procedures we use in our extreme level race engines.
WRX 275
$975 Shipped
STi 278
$999 Shipped
Helix Easy HP Combo
Gains of up 30 whp+ (with proper tunning)
-Helix Non-Catted DP
-Gruppe-S Unequal Length Manifold
-Helix Up-Pipe (Non-EWG Version)
-Free CEL Fix
$625 Shipped
Combo with Gruppe-S Equal Length Manifold
$749 Shipped
The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. The outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly
$349 Shipped
Gruppe-S Equal Length Exhaust Manifold
Free Helix Up-Pipe
Constructed from T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. Dyno proven to make up to 8hp and 12 ft-lbs of torque. The design of the Gruppe-S equal length manifold increses boost response. Spool up time is decreased incresing boost pressure at lower RPM's. Due to the exhaust pulses now being paired together the lumpy boxer sound is lost instead a smoother sound is produced.
2.0L Engines Require 2.5L Oil Pan For Manifold Clearance
WRX/ Legacy/ Forester/ STi 2.5L
$599 Shipped
WRX/ Forester/ Legacy 2.0L
$699 Shipped (STi Oil Pan Included for Propper Clearance)
New Helix Up-Pipe
- 44mm id
- stainless steel construction
- robotic tig welded flanges
- machined flanges
$125 Shipped
Helix Down-Pipes
Non Catted
$199 Shipped Free CEL Fix
Catted
Sold out. ETA End Of April
Create your Custom Turbo Back Exhaust
Performance Exhaust
Helix DP/HKS Hi-Power- $699
Helix DP/HKS HKS Carbon-Ti- $775
Helix DP/GReddy TI-C- $640
Helix DP/Blitz NUR Spec- $699
Quiet Exhaust Under (93db)
Helix DP/A'Pexi World Sport- $625
Helix DP/Apexi WS NOIR- $675
Helix DP/GReddy SP2- $699
Helix Dp/Tanabe Medalion Touring- $699
Helix Intercooler Y-Pipe
The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing and increasing the airflow, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs.
$75 Shipped
Gruppe-S is offline
Old 03-31-2008, 05:45 PM   #2
Trader Rating: (13)
Default Re: BC Cams Now Available-Cosworth InStock-Unequal Length Manifolds-Turbo Back Combos
Spearco Top Mount Intercooler
Spearco TMIC Kit 02-07 WRX
Free Gruppe-S Intercooler Y-Pipe for WRX
PM For Price
IHI VF22 Turbo 375HP Package
The IHI VF22 is a DIRECT bolt-on upgrade for your WRX. The turbo makes big power! The VF22 adds mid-range punch as well as vastly-better top-end performance vs. the factory Mitsubishi TD04. Typical gains are 20% in peak horsepower, and a whopping 30% gain in torque over the stock turbo at redline! BIG compressor housing means lots of nice cool air, even at relatively high (20 psi+) boost pressures.
- IHI VF22 Turbo
- STI 565cc Injectors,
- Walbro GS342 Fuel Pump w/ setup kit
IHI VF22 Turbo 375HP Package $1375 Shipped Now $1299 Shipped
VF22 Turbo $799 Shipped Now $749 Shipped
MHI 18G Turbo 400HP Package
The new MHI TD05H 18G turbo for Subabru WRX. With 7cm2 turbine housing, also included are water lines and oil drain line. This high-powered upgrade is good for 400 HP and flows 600 cfm! 1yr warranty. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines.
-MHI 18G Turbo
- PE 650 or 800 cc Injectors,
MHI 18G Turbo 475HP Package $1250.00 Shipped
MHI 18G Turbo $749.00 Shipped
ATP GT30 Turbo 450HP Package
Xtreme EVO Killer System
-GT3076R/ or GT3071R Turbo
-Hydra EMS
-Perrin 3" Turbo Inlet Pipe
-Denso 860cc Injectors
-Walbro 255 lph Fuel Pump - w/ Setup Kit
$3999 Shipped to the door.
Pro Max System
-Cobb Accessport
$3199 Shipped
Street System
-Cobb Accessport
$2950 Shipped
ATP GT3076R/ or GT3071R Turbo
$1799 Shipped
Cusco Engine/Tranny Mount Combo
$259 Shipped
Engine Rebuild Kits
EJ20 Engine Combo/ EJ25 Engine Combo
-CP (std) or (+020) Pistons
-CP Piston Rings
-Helix Forged Rods
-Coated Race Bearings
$799 Shipped
EJ25 Budget STi Engine Rebuild Kit
Brand new components. Taken out of a brand new USDM EJ257 STi Shortblock. Brand new with zero miles.
-USDM STi Pistons
-USDM STi Piston Rings
-USDM STi Rods
-USDM STi Bearings
$599 Shipped
Gruppe-S is offline
Old 04-01-2008, 09:51 AM   #3
Trader Rating: (13)
Gruppe-S is offline
Old 04-02-2008, 10:07 AM   #4
Trader Rating: (13)
Gruppe-S is offline
Old 04-03-2008, 11:55 AM   #5
Trader Rating: (13)
Gruppe-S is offline
Old 04-07-2008, 01:21 PM   #6
Trader Rating: (13)
Gruppe-S is offline
Old 04-08-2008, 10:09 AM   #7
Trader Rating: (13)
Gruppe-S is offline
Old 04-08-2008, 09:35 PM   #8
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
very nice
mofoSTI is offline
Old 04-09-2008, 09:42 AM   #9
Trader Rating: (13)
Gruppe-S is offline
Old 04-10-2008, 03:30 PM   #10
Trader Rating: (13)
Gruppe-S is offline
Old 04-11-2008, 01:13 PM   #11
Trader Rating: (13)
Gruppe-S is offline
Old 04-14-2008, 10:36 AM   #12
Trader Rating: (13)
Gruppe-S is offline
Old 04-15-2008, 10:16 AM   #13
Trader Rating: (13)
Gruppe-S is offline
Old 04-16-2008, 10:10 AM   #14
Trader Rating: (13)
Gruppe-S is offline
Old 04-17-2008, 10:39 AM   #15
Trader Rating: (13)
Gruppe-S is offline
Closed Thread
